Old 01-08-2006, 02:22 PM   #21 (permalink)
Will
oh so LAZY
but what is the headcode? the exhaust manifold you speak of sounds like a VE manifold.
so it is a highport, internal coil, silver VC, can you just look in the spark plug holes and see if the pistons are flat topped?
Click for My Car Pics
White '92 NX2000 All Stock.
Will is offline   Reply With Quote
Old 01-09-2006, 09:45 PM   #22 (permalink)
BRE92SER
SE-R Geek / Nissan Tech
yeah I'll look tomorow and let yah *** what they look like. The headcode is 4R, and it has the ribs on the chain-channel
USE THIS FIRST!!!
V
http://www.sr20forum.com/search.php
Old 01-11-2006, 12:12 AM   #23 (permalink)
BRE92SER
no luck....all I see is a dark fluid substance!
...guess i'll have to replace that HG after all....i just hope it doesnt need stem seals, too
maybe thats the reason the h20 pump bearing was so bad, and all the hoses are so gummed up..?
Old 01-11-2006, 12:25 AM   #24 (permalink)
venom2727
www.wheelsjamaica.com
Originally Posted by venom2727
the engine is a primera engine the code on the block reads 53J 3L it has the black stream in the middle . i saw on this thread that the engine with this code is a 10:1 JMD engine with a 7 and a slash thru it under the coil , but when i look under my coil i see a 8 with a slash thru it.
is this the same engine /or is there a difference? what does the 8 means?
can anyone explain this engine
venom2727 is offline   Reply With Quote
Old 01-22-2006, 02:15 AM   #25 (permalink)
I8URV8
Smoke Tires Not Drugs
the numbers on my head are 53J 1L and a 5 in the 1 inch circle by the coil. could someone tell me what engine this is?
I8URV8 is offline   Reply With Quote
Old 01-25-2006, 09:17 PM   #26 (permalink)
grinch77
Fun Hater
Thats the numbers on my head also champane color.^^^
grinch77 is offline   Reply With Quote
Old 02-08-2006, 06:46 PM   #27 (permalink)
iz_cool
Originally Posted by JTstyle
Finally got around to reading mine. 53J 6R Looks to be silver or gold VC with black channel
Hi guys! Need some info on this pls?
We found a redtop SR20DE.
It had UK1 96J on its injector, but when we looked at the number under the distributor cap it has 53J 6R we also found another one it had 96J 1L.
Are these engines ok? Or had they been tampered because they dont have the same code.
Thanks.
iz_cool is offline   Reply With Quote
Old 02-08-2006, 11:12 PM   #28 (permalink)
BRE92SER
going by the #s on the list its a UK 10:1 motor with sodium filled valves. what color are the injectors?
Old 02-09-2006, 12:15 AM   #29 (permalink)
iz_cool
Its silver or gray.
Old 02-09-2006, 12:28 AM   #30 (permalink)
BRE92SER
congrat's, you have a UK SR20DE 10:1 with sodium filled valves. how much you get it for? its a great motor, and just like all sr's, it loves mods!
Old 02-09-2006, 12:43 AM   #31 (permalink)
Will
oh so LAZY
It also takes boost very well. I have seen a t28 at 12psi on 10:1 DE motor in a b14 full interior go 12.6 on street tires.
Old 02-09-2006, 01:44 AM   #32 (permalink)
iz_cool
Thanks for the replies.
Also just want to know from what engine the 53J 6R came from?
Old 02-19-2006, 10:41 AM   #33 (permalink)
nomad
smoke and a Pancake
guys...i have a 53j 2r motor on my b14 and its not turbo or *** so ever so if you guys can explain *** type of motor i have and *** car it came from cause i have a motor swap.
thanks
nomad
I my Nissan
WHITE 96 200sx se-R
shift_..
__________________________________________________ __
USPS classifies Guam with the rest of the USA as far as shipping rates go...
Check UPS and see if they have USPS rates. Thank you.
nomad is offline   Reply With Quote
Old 02-19-2006, 05:26 PM   #34 (permalink)
nsn240
sr20 240sx
52F - Larger Exhaust Valves Silvia engine
do you have any more information on this head?? im assuming its still the 9:5:1 compression
89 240sx sr20de/t
pa-nissans.com
nsn240 is offline   Reply With Quote
Old 02-19-2006, 10:43 PM   #35 (permalink)
nomad
smoke and a Pancake
thanks
nomad
come on guys i did some searching and its hard to find
Old 03-10-2006, 05:57 AM   #36 (permalink)
dirrtyjave
garage life
hey guys i just purchased an sr20, but till now i still haven't determined what type of sr20 it is. the stamps i saw said 1R 2J2. so far i've done a search but still came up wanting.
anyway here are some parts i took into cosideration, hope you guys can identify teh engine for me:
bare silver valve color
internal coils for the distributor
tubular exhaust manifold
low port
ribs
*the supplier said the engine came from a 98 model jdm primera.
thanks for teh help guys
dirrtyjave is offline   Reply With Quote
Old 03-10-2006, 07:24 AM   #37 (permalink)
XxToKeSxX
XxToKeSxX's Avatar
Trader Rating: 42 (100%)
Guys, a lot of this stuff is all in the first post... thats what this post was for!
dirrty jave, looks to me you have a jdm roller rocker primera... check the first post though and search a bit... check my sig on roller rocker information.
1998 SE-R | S3Rs/I/H/E/M | 99.9% Daily Driver | Rubí DeL FuegO
1991 nX-T | My Boost Slut | 00.1% Daily Driver | The Deviled Egg
Shift_Down to 2 Vehicles...
Old 03-10-2006, 08:48 AM   #38 (permalink)
dirrtyjave
garage life
hmmm, is this the same as the 2r 2j2 sr20de? hahah, i seem to findmyself a little bit confused while reading the list coz if i just refer to the 1r staping, its gonna refer to the usdm engine, but if i refer to the 2j2 stamping, its gonna refer to the jdm engine. whats the hp rating of the 2r 2j2 engine? thanks bro
Old 03-10-2006, 09:19 AM   #39 (permalink)
XxToKeSxX
XxToKeSxX's Avatar
2j2 generally refers to roller rocker... Check the Block/Head... is there a 53J?, keep looking for distinguishing markings... You have to investigate more... injector color, the kind of intake manifold, it seems that what the dealer is telling you may be right... it sounds like its a primera engine to me, but give yourself piece of mind and try to verify.
as for roller rocker information and power, compression, tq ... again, please look at the link in my signature.
Old 03-11-2006, 02:02 AM   #40 (permalink)
dirrtyjave
garage life
tokes,
hmmm, thats weird. i checked both sides of the block already and i still cant find any reference to 53J. the last place i havent checked yet would have to bein front of the block, the area the exhaust manifold is covering. btw, i noticed that our engines look 95% alike, what does your block stamp say?
i just hope my sr20 isn't the SR20Di or the SR20De.
hot version b13
Team VcZR
