Old 02-17-2002, 01:38 PM   #1 (permalink)
Nos Slut
How does a catch can work?
I was just wondering how u guys set this up?
I seen pics of the cans and it looks like most have 2 inlets.
do the 2 hoses from the valve cover just go to the can?
does the pcv valve stay i place?
i also seen cans with a breather? dont all catch cans need this since one hose sucks in air?
just trying to educate myself
95 200sx SER
PS Header w/ 2.5" Collecter| 3" Intake w/ POP| 2.5" Exhaust w/ Cherry Bomb Pro muffler| ES Bushings| NX2000 Sway Bar| 91 Intake Cam| G20 Ecu
96 Sentra 1.6(B13)
Lightend stock flywheel| ACT HD PP w/stock disc| UR Crank+PS Pulley| 3" Intake w/ K&N Cone| XS Power Header| ES Bushings| ST Sway Bars| 2" Exhaust w/ Magnaflow Muffler| 60mm TB| Intrax Springs| 50hp Shot NOS
HaulinSentra is offline   Reply With Quote
Old 02-17-2002, 04:17 PM   #2 (permalink)
NISSAN SOLDIER
heres all I know so far.
Oil vapors go up and condense on the perforated metal plate. Only air can pass thru there. The air gets sucked out while the oil condensed falls back down. If you put a breather filter on, this can will not work properly if at all. I have it set up normally. Which I would recomend. You need that intake suction to get this thing working properly. Why is this mystery box there in the first place?
Who knows?
Jonathan
93 G20 "Im cruising tonight"
Old 02-17-2002, 04:34 PM   #3 (permalink)
Nos Slut
i think your talking about the oil seperator on the 91-94 sr20de..
thats what i am understanding..
the catch can has the spot for the 2 hoses. both are up at the top of the catch can?
Old 02-17-2002, 04:39 PM   #4 (permalink)
NISSAN SOLDIER
OH. My bad.
Old 02-17-2002, 04:52 PM   #5 (permalink)
Nos Slut
i think i saw some pics of a couple turbo cars here with the catch can... can someone post pics of thier setup?
Old 02-18-2002, 10:44 AM   #6 (permalink)
Nos Slut
I finaly found a pic, so here it is
here is a link to the site which explains on how it works with some installed pics.
http://cjsupra.kendra.com/PCV-Can.html
I understand the drift of things now, but now thier is no engine vacuum sucking the air out of the valve cover it just freely comes out at whatever pace? Also do they keep the pcv valve inplace or just run the hoses to the catch can?
