Last night I flushed out my coolant system, replaced my thermostat, and then re-filled the coolant system. I was following the
instructions on zotz.com.
Once I put coolant in the car, I started the engine. Those instructions say "After the radiator fan begins to run, allow the engine to run a few more minutes, then shut down." My car ran at idle with a load on it(headlights, foglights, and rear defroster on,) and the temperature looked fine, but the fan didn't turn on. After about 20 minutes, smoke started coming from the area near the radiator cap and the area by where the lower radiator hose connects to the radiator. It smelled like burning coolant I think, so I immediately shut off the car.
Since my SE-R is my only form of transportation right now and I have no internet back at my parents' house, I just waited an hour and finished up the procedure. My heat still isn't as hot as I'd like it to be...in fact, it's barely warm. The car acts fine though...no overheating or anything like that. But the smoke worried me. Shouldn't the fan have turned on? Is there a way to test the sensor on the engine that triggers the fan?
