i am leaking oil from underneath my car...sometimes it leaks a little after i park or it leaks like alot at times but not lika alo-alot but just enough to notice...
why could this be happening and where could it be coming from? maybe th eoil pan? well what are yall suggestions....plz help thanks
you only need one thread, which i already posted in, btw i forgot to mention the valve cover gasket
Here's a suggestion, jack the car up and crawl underneath it! Once you've found the area from where the oil is leaking from it should be fairly easy to tell what's causing it
Also, I deleted your other thread... besides being in the wrong section, we don't like double posts
