Old 05-04-2007, 10:22 PM   #1 (permalink)
fu*k Your Vtac
Waterpump replacement, how to?? how hard??
Okay well my waterpump decided to go on my 93 sentra, ga16....
and i know where its at, it looks like a pain in the ass to do, so *** are your guy's opinions?? can u explain the procedure?? i searched for a write up with no luck...how hard will it be???
Thanks
-Josh
93 Se converting to Se-r, Aviner going in soon!
Check out the project thread.
91 Se-r on crack, weight reduction whore, possibly getting VE
NoLmit-B13 is offline   Reply With Quote
Old 05-05-2007, 03:31 PM   #2 (permalink)
Wiggle wagon driver...
Trader Rating: 26 (100%)
the easiest way to do it is to drop the engine until the water pump clears the frame rail. i tried to do it while the engine was bolted in, and iirc there is(are) one or more bolts that you will not be able to remove. if you drop the engine it is as easy as removing the coolant line (which is a pain in the ass) and removing a few bolts. you will also want to make a note of where each bolt goes. mine were different lengths.
200sx w/JDM highport swap..turbo build in the works
05 Altima
01 F150
Originally Posted by KdubL View Post
she looks funky...like she just finished eating a doo doo samich
Katana200sx is offline   Reply With Quote
Old 05-05-2007, 04:39 PM   #3 (permalink)
fu*k Your Vtac
uh oh thats kind of scary, lol sorry never got that far into working on a car but noob question i guess?
how do u drop the engine, undo which mounts and *** else than can i use a jack or do i need a lift???
Old 05-05-2007, 05:10 PM   #4 (permalink)
the proof wizard
just undo the pass side motor mount, and jack the car up to get some of the bolts on the top, and you can lower it down a little to get the bolts on the bottom side of the water pump, its not that fun but its not impossible.... just get in there and do it
edit i just saw that this was in a ga16, id just suggest replacing the motor with an sr....jk
12sec NA
Old 05-05-2007, 05:27 PM   #5 (permalink)
fu*k Your Vtac
lol alrite thank you, ill give it a shot and let u guys know how it goes...
