g20 wont rev past 2k rpm - SR20 Forum
Old 07-11-2007, 06:59 PM   #1 (permalink)
Feedback Score: 3 reviews
Hey
I would have searched but I have no cpu so any help is greatly appreciated. have a 96 g20 with a 99 motor the car won't rev past 2k rpm in any gear or neutral. It idles fine and drives fine under 2k. I think most likely its the distributor but wanted some thoughts from u guys so post up thanx a lot peace
Mister Jew is offline   Reply With Quote
Old 07-11-2007, 09:18 PM   #2 (permalink)
Drive Like Gas Is Cheap
Originally Posted by Mister Jew View Post
Hey
it's your distributor 100% sure
B13 Sentra SE-R.
92 Black13 is offline   Reply With Quote
Old 07-12-2007, 12:41 AM   #3 (permalink)
Ok well I put in another distributor and same thing I unplugged the maf and the car did not shut off than I replugged it in and the car shut off.. I believe the car is suppose to automatically shut off? I than went to clear the check engine light which iturned on when I unplugged the maf. Than the car revved over 2k so maybe the car was in safe mode? The other code it threw was coolant temp I had 0 codes before all of this. Please post up any ideas or thoughts please thanx a lot peace
Old 07-12-2007, 01:14 AM   #4 (permalink)
so the distributer didnt work?
Blimpy is offline   Reply With Quote
Old 07-12-2007, 01:14 AM   #5 (permalink)
so the distributer didnt work?plz post if u fix it *** same thing happens to mine ill do the same
Old 07-12-2007, 02:39 AM   #6 (permalink)
No it did not work. It started running right after I cleared the codes that I caused by unplugginh the maf. I fixed it but don't know what was originally wrong so regardless I want too figure out what's wrong.
Old 07-12-2007, 03:18 PM   #7 (permalink)
well ive got three thing i got it down too its either my maf bad or bad ground um... bad o2 sensor.... or bad temp sensor.
Old 07-12-2007, 03:41 PM   #8 (permalink)
Travieso Racing
Feedback Score: 6 reviews
its the maf.... either bad ground or lose connection by the ecu..
also could be the ecu thats burnt
Danny GDM (HKS)
1993 PRiMERA GT
Old 07-12-2007, 04:18 PM   #9 (permalink)
!!!!CAUTION!!!!
blurr.rt.by.you's Avatar
Feedback Score: 69 reviews
check the voltage at the maf at idle then WOT. once you either re-ground it or replace it. make sure you reset your ecu.
***GARAGE SALE***
http://www.sr20forum.com/mechanical-oem-part-outs/215172-garage-clean-up-sale.html
http://www.sr20forum.com/mechanical-oem-part-outs/217115-more-stuff-sale.html
blurr.rt.by.you is offline   Reply With Quote
Old 07-12-2007, 05:49 PM   #10 (permalink)
yeah what should the voltage be of the maf on idle what if its below or above the voltage?
Old 07-12-2007, 05:52 PM   #11 (permalink)
G20 newb, not se-r geez!
very good chance that it's the maf, same thing happened to me and it was that the maf was loose.
JGG8891 is offline   Reply With Quote
Old 07-12-2007, 07:02 PM   #12 (permalink)
well right now the car is running fine so i have no way to diagnose the problem now because it isnt doing it anymore.
what would cause the car to go into safe mode? a bad sensor is what i thought but i never got a check engine light so thats why i am confused.
Old 07-13-2007, 01:03 AM   #13 (permalink)
it could be a loose sensor if it does it again try checking the sensors
Old 07-13-2007, 04:08 PM   #14 (permalink)
Travieso Racing
clean battery terminals?
Old 08-11-2011, 01:14 AM   #15 (permalink)
What sensor can it be? My cars doing the same
punkrockprs is offline   Reply With Quote
