I hate exhaust leaks!! - SR20 Forum
Old 07-28-2007, 03:00 AM   #1 (permalink)
Feedback Score: 6 reviews
I had a leaking flex section on my SSAC header which I thought was the only cause of my exhaust leak. I got a new flex section welded in thinking everything would be back to normal but I still smell exhaust fumes.
I dont know if Its because I dont have a cat or because I still have a leak. I think there may also be a leak where the header bolts up to the block.
Im wondering how I can check for leaks without having to remove the header. What are some ghetto fixes for sealing up that area without having to remove the header?
I was thinking of some liquid gasket around the edges?
fullahwickednez is offline   Reply With Quote
Old 07-28-2007, 09:58 PM   #2 (permalink)
agent camel toe
Feedback Score: 22 reviews
never used lg before..throw some soppy water on the though to be leaking gaskets and start the car--do this when cold..a new gasket is only $19 from summit http://store.summitracing.com/partde...view=sku--head to manny..and the primary to secondary is only 9
just upgrade both to the copper type and she wont leak again
nyce1s.com
R.I.P. RESPECT SR.
96 b14 det--under the knife
2002 quest gxe--pimp wagon
Old 07-29-2007, 11:11 PM   #3 (permalink)
thanks for the tip. Its not so much the cost of the gasket, I just remember how much of a bitch it was to get the header on. Im trying to avoid having to take it off and going thru that headache again but, I guess it looks like I have no choice.
arrrhh.
Old 07-29-2007, 11:26 PM   #4 (permalink)
agent camel toe
remove the fans first for better clearance..
Old 11-16-2007, 09:11 PM   #5 (permalink)
Im Not A Chick
Feedback Score: 5 reviews
old thread but i was looking around and i need the gasket between the header and the secondary.. my sh*t completly blew out and i made another one using sheet metal and it worked fine but now for a while but now im starting to look at it and its falling apart..
somebody told me sumit makes a similar one but i cant find it..
B13 XE with sr20 swap(5 speed swapped)
B13 LE parts car
NX2K RIP (Aug 13 2007) parts car
NX2k soon to be parts car
NX2k my new baby!
NX PART OUT CHECK IT OUT!
http://www.sr20forum.com/mechanical-...-nx-parts.html
We are a community!
jen36 is offline   Reply With Quote
Old 11-18-2007, 08:54 PM   #6 (permalink)
Broke Ass
jer_760's Avatar
Feedback Score: 12 reviews
http://store.summitracing.com/egnsea...DS=1&N=700+115
95 200sx
sr20ve
Old 12-02-2007, 04:09 PM   #7 (permalink)
I know that the SSAC Pri/Sec gasket that came with it doesn't fit well. You need to slot one of the holes. I wonder if that Summit one will drop in or not? Looks about the right shape, but who knows? Let us know if it works out!
As for leaks, the EGR seal (or lack therof) on those suck.
Check these:
http://www.sr20forum.com/naturally-a...r-gaskets.html
_SHig
SHigSpeed is offline   Reply With Quote
Old 12-02-2007, 11:35 PM   #8 (permalink)
agent camel toe
Check these:
_SHig
the summit unit fits like a glove..i have used the same gasket already x3 and no leaks
Old 12-03-2007, 02:09 PM   #9 (permalink)
SR20 apprentice
Feedback Score: 16 reviews
Anyone use this gasket with the SSAC header?
http://store.summitracing.com/partde...5&autoview=sku
Tommy's 98 SE
Old 08-09-2008, 02:27 PM   #10 (permalink)
Turd Furgeson
Benito Malito's Avatar
Feedback Score: 41 reviews
bumps it. does anyone know a part # for one of these that I could get from NAPA autozone etc?
1992 SuperBlack VVL SE-R
1994 P10 KL0
2004 Forester XT SGM
Old 08-12-2008, 12:55 PM   #11 (permalink)
Turd Furgeson
So nobody knows? I guess I'll order one from Summit.
There's no equivalent gasket from like Felpro or any other manufacturer? There's a whole wall of felpro gaskets at the local place.
Old 06-17-2011, 06:04 PM   #12 (permalink)
Do you have any more of these?
davin550
1995 200SX SE-R; 5MT; no sunroof
Hyperco's w/ AGX struts; Suspension Techniques Rear Sway Bar; Stillen FSTB; Ebay RSTB
Place Racing Cold Air Intake; B&M Short Shifter; Ultra Wires with indexed plugs; JWT S3 Cams; JWT ECU
davin550 is offline   Reply With Quote
