Are these sensor quite sensitive? The reason I asked is because I tapped out the sensor from another Primera in the scrappy to replace mines but have yet to do so. I ha to tap from the inside of the spindle and the sensor tip is a little disfigured, not a lot but a little bent. As far as I know the sensore is just there to pass a signal to the teeth within the hub. Do you think that the sensor being a little tattered would be a problem or are they pretty rugged?
Datsun 1600 Project 450HP
Project 2008 AWD B13 4-door 500HP
97 Silvia S14/200SX------->
99 Silvia S15/200SX------->
