Clutch engagement issue? - SR20 Forum
Old 09-30-2007, 08:03 PM   #1 (permalink)
Hey everyone. Im having some problems with what I believe to be my clutch. Ive tried searching the forum to no avail. The problem is when I put the car into reverse the car will jump back, stall and die. It also seems to not want to go physically into the reverse position unless the car is turned off. Any input helps. Thanks
Adding fuel to the fire since 1986...
scooba paul is offline   Reply With Quote
Old 09-30-2007, 09:33 PM   #2 (permalink)
Always Dubbin'
Feedback Score: 5 reviews
any problems with forward gears?
My Garage:
03' VW GTI - 24v VR6/6spd/Slammed - Daily
03' VW GTI 20th Anniversary - 1.8t/6spd/20psi - Back Home
91' B13 SER - 10:1 SR - U12 T25 - 248whp@13psi (traded)
93' B13 SER - 8.5:1 SR - U12 T25 - 215wph@10psi (traded)
92' B13 SER - 9.5:1 SR - Bolt Ons (sold)
91' B13 SER - 9.5:1 SR - Cammed (sold)
92serturbo is offline   Reply With Quote
Old 09-30-2007, 10:02 PM   #3 (permalink)
Travieso Racing
Feedback Score: 6 reviews
... motor mounts could be really fukin bad an the motor isnt being positioned correctly.
Danny GDM (HKS)
1993 PRiMERA GT
Old 09-30-2007, 11:13 PM   #4 (permalink)
eek. Well supposedly it has nismo mounts and the engine 'appears' to be straight and it doesnt shake or vibrate. But then again I am nowhere near expert on engine installs 101. Every other gear is fine. Nice and straight. Is there anything particular I should look for.
Old 10-02-2007, 11:33 AM   #5 (permalink)
Ok, so went to to attempt to move it and the car WILL NOT go into ANY gear when the car is running. When the car is turned off, however, the gears go into place as they should. My mechanically challeged stepdad added that it may be the clutch clave cylinder. But I can feel the clutch engaging when I press it.
Once again, starting the car while in gear results in the car 'bucking' and stalling. And sorry I forgot to add, though i'm not sure if it helps or not, the car is an S13 with an S13 redtop..
Old 10-03-2007, 08:01 AM   #6 (permalink)
Darwin Award Winner '02
Feedback Score: 15 reviews
Well since you feel tension on the clutch then the cable is still connected. So you are going to have to adjust the cable to get into gear. The fact it started w/ reverse and is now affecting forward gears sounds like an adjustment issue. But if you adjust it all the way and you still get nothing, then thats where it becomes a clutch problem. But I would check the cable first and also the clutch lever to make sure it isnt cracked and adding slop.
Pru
Team NABR
91 SE-R DE-T GT28R, P11 tranny
90 Mitsu GSX 397hp 374tq GT30R, Shep tranny
93 K1500 35" Buckshots, Detroit Truetrac, 3.73s (sold)
93 Laser RS s16g (Totaled)
92 Talon E316G (Totaled)
95 Cherokee 3" 31 BFG A/T KO
99 GXE Wifes car
"People like you are the reason metal coat-hangers can be untwisted and fashioned into convenient hooks."
Froyd79 is offline   Reply With Quote
Old 10-09-2007, 09:06 PM   #7 (permalink)
scooba paul, any luck finding out what the problem was. if you find out, pm me or post because i'm having the same problem. i was told it's either the clutch or pressure plate.
assassin is offline   Reply With Quote
Old 10-10-2007, 08:29 PM   #8 (permalink)
Feedback Score: 13 reviews
unless this situation occurs directly after a clutch installation, you more than likely have a blown clutch disk
peices of the clutch are doubling up in thickness causing your clutch to stay slightly engaged so you cant go into gear when the engine is idleing and you will move if you start the car in gear regardles of the clutch pedal being depressed
dxpxe is offline   Reply With Quote
Old 10-10-2007, 09:07 PM   #9 (permalink)
Certified Nissan Tech.
i had the same issue about 2 weeks ago. it was the clutch. one of the springs in the disk and broken and the fragments were keeping it engaged. I changed the cable first because the old cable was adjusted to the max. that didnt fix it, so i changed the clutch and sure enough....
06 Blackout Sentra 1.8Special Edition, SR swap soon
92 Sentra XE, the beater
WAFFLES is offline   Reply With Quote
