MAF Confusion - SR20 Forum
Old 10-10-2007, 04:19 PM   #1 (permalink)
GA 2 SR
MAF Confusion
Is there a difference in MAF from a JDM 90-94 SR20 to a USDM 95-98 SER? Can you hook up a 98 SER MAF with 98 SER HArness to a 91-94 JDM Engine? I am having lopey idle and misfire because my computer is not reading the signal from the MAF I've tried a 91-94 SER MAF and a new 95-98 SER MAF that I ordered from Rock auto with no luck. Any Help will be greatful.
"Momento Vivere"
Pholkus is offline   Reply With Quote
Old 10-10-2007, 04:21 PM   #2 (permalink)
SR powered S13 coupe
McCoy's Avatar
Feedback Score: 78 reviews
You need to match the MAF to the ECU, shouldn't be that confusing.... that goes for the wiring harness too.
Old 10-10-2007, 04:25 PM   #3 (permalink)
GA 2 SR
Ok, so lets just say that I had a 98 SEL and I swapped the ECU with a 96 SER, then you are telling me that the 98SEL will not run right?
Old 10-10-2007, 05:19 PM   #4 (permalink)
McCoy's Avatar
I'm saying if the part #'s of the MAF's are the same then you will be fine.
