B14 - P10 MAF interchangeable? - SR20 Forum
Old 10-11-2007, 12:57 PM   #1 (permalink)
Having trouble finding this one. Will my B14 MAF work with an ECU programmed for a P10 MAF?
Thanks.
zerosin is offline   Reply With Quote
Old 10-14-2007, 10:58 PM   #2 (permalink)
_______
Mike's Avatar
Feedback Score: 57 reviews
What year p10?
The easiest way to find out is to look at the part numbers on the two mafs.
Mike
Mike is offline   Reply With Quote
Old 10-15-2007, 09:58 AM   #3 (permalink)
It's for a JWT ECU programmed for a P10 MAF, not sure what MAF exactly. I have the B14 MAF.
Old 10-15-2007, 10:18 AM   #4 (permalink)
Done.
Feedback Score: 27 reviews
Forgive my stupidity, but isn't the P10 the same as a B13?
I couldn't find anything specific, but I thought that they were the same?
SR20DEEP MD
05 Armada - Tow Truck
04 Subaru WRX 'goon
Cliff está en línea   Reply With Quote
Old 10-15-2007, 10:41 AM   #5 (permalink)
Travieso Racing
Feedback Score: 6 reviews
p10 91-93 same sh*t as b13 maf
p10 93.5-96 b14 maf is the same
Danny GDM (HKS)
1993 PRiMERA GT
Old 10-15-2007, 11:29 AM   #6 (permalink)
Turd Furgeson
Benito Malito's Avatar
Feedback Score: 41 reviews
Are you sure they swapped mafs earlier than engines Danny? The 93.5 G20s were still highport engines.
1992 SuperBlack VVL SE-R
1994 P10 KL0
2004 Forester XT SGM
Old 10-15-2007, 12:30 PM   #7 (permalink)
AWD owns me
Jaketips42's Avatar
Feedback Score: 12 reviews
Just match up MAF part numbers. The huge list of themis on here somewhere.
Sporting the GC awaiting EJ20T
____________________________________GC Pilot
Subaru stole me from Nissan
Old 10-15-2007, 02:31 PM   #8 (permalink)
If only JWT put what MAF part number they programmed for instead of just "P10". I don't know what year they programmed for but I suspect a '95.
Old 10-15-2007, 03:38 PM   #9 (permalink)
_______
Mike's Avatar
This isn't very mind boggling if you think about it. If the ECU is OBDII then you can use the b14 maf. IF the ECU is OBDI then you can't use the b14 maf.
Simple as that.
Mike
Old 10-15-2007, 03:42 PM   #10 (permalink)
_______
Mike's Avatar
Answer...
Correct.
Old 10-15-2007, 03:44 PM   #11 (permalink)
_______
Mike's Avatar
They swapped mafs when they swapped to obdII (93.5+).
Mike
Old 10-15-2007, 10:39 PM   #12 (permalink)
Turd Furgeson
Mike
So they went obdII on the last highports? I've seen 93.5s when I was looking for a car earlier this year (bought the 98) and they looked like the early P10s with airbags/keyless etc...
Old 10-16-2007, 05:35 PM   #13 (permalink)
_______
Mike's Avatar
Either they used the highports or they switched to lowports halfway through the year. I'm not to sure.
Mike
Old 10-16-2007, 07:55 PM   #14 (permalink)
Simple as that.
Mike
Cool, thanks.
