Originally Posted by CovertRussian
I'm sorry to hear Lurch
What kind of intake are you running? Your engine could possibly be chocking and not getting enough oxygen.
Is that 140ft/lbs torque at the wheels or crank?
sorry mate...i totally missed your post there...i'm not ignoring you i promise...lol...just a bit dense!
Well i ran very near the start (about 25 of us running during the day) and i got the disappointing figure...so talked to everyone there...had a big old brainstorm and headscratch and tried to think of things....talked to the RR guys and they wondered whether it could be oxygen starvation at the top end so they put it back on the rollers at the very end and just whipped the filter off to see if that could of been the issue...
they checked the timing and that was fine...they checked i was hitting full throttle at the butterfly, checked the fuelling on the wide band AFR and they couldn't see any issues whatsoever...(all for free by the way so a huge big up to Power Engineering down in Uxbridge....couldn't of done more for us for free...top lads!!!)
oh and it was 140ft/lbs at the crank
some other things they mentioned was that the Big bore throttle body could be too big and stagnating the air a little...
also that the cams are not violent enough to feed the top end of the power band with the bigger tb etc...
i've got a couple of days off from tommorow so i'll get the leak down and compression test done and let you know the results...
oh and i was looking at the big cam list...and was looking at the stage 2 HKS cams...looked around online for them and they are all listed under SR20DET rather than SR20...
would they be alright in an SR20? Or is it purely SR20DET kit??
Cheers
