It's really a simple matter of finding all the grounds, and replacing them. Possibly adding more than there were to begin with. As far as I know, the B13 has grounds from the engine to the chassis right by the battery/thermostat housing, and another one from the chassis to the lead exhaust pipe. Your B14 should be similar. I like to add another ground from the passenger side of the intake manifold to somewhere on the chassis by the power steering lines. Once, again, this is a B13 so your results may vary.
I like to buy power cable, and ring terminals from
www.partsexpress.com . They are a great supplier, and have good prices.
I'd buy about 4 feet of this 4 gauge wire:
http://www.partsexpress.com/pe/showd...number=100-196
and
6 of these ring terminals:
http://www.partsexpress.com/pe/showd...number=263-625
That should get you set for the two main factory grounds, and an extra like I was talking about. On second thought, I'm not sure how that rubber insulation will cope around the exhaust pipe. You might want to do a typical grounding strap for that one, like they have form the factory.
