Major flooding, Now engine wont crank. - SR20 Forum
Old 10-16-2007, 10:44 PM   #1 (permalink)
While setting the base timing on my car (sr20de with Link lem G3 ecu)
with the fuel turned OFF on the link the engine all of a sudden stopped cranking like it was in gear or siezed.
So i pulled out the plugs and cylinders 2 and 4 were FULL of petrol.
This means for some reason yet undetermined(*** it started raining) the injectors were switched on all of a sudden, either by the link or more likely by shorting to ground. BTW i have injectors 1 & 3 wired together and 2 & 4 the same.
anyway i blew out the petrol with compressed air, replaced the plugs and it still wont turn over
what are the chances I've bent a rod or maybe damaged the starter motor?
i just want to determine why it wont crank so i dont do any(or more) damage.
sr-starlet is offline   Reply With Quote
