So.... i was removing the oil pan and didnt know there were two more bolts behind the cover on the rear of the oil pan... started to get the pan off and cracked the engine block.... The crack goes up about 1/4" and all the way through... There's no gap, that i can tell.. what now?! Can i use JBweld or something? What do i do.... Please HELP!!!!
There he goes one of gods own prototypes. A high powered mutant of some kind not even considered for mass production. Too weird to live and too rare to die
After closely looking at this what i cracked is the rear engine cover??? Im not sure what it really is called, but it holds the rear main seal in.... it cracked in half... after loosening two of the bottom bolts the bottom portion of it fell off.. so now the question is where do i get one of these?!?!?!
Yeah just replace that rear main seal housing and you should be good to go. Its happened to many others before so don't beat yourself up over it.
My heart stopped when it happened, i thought it was the whole block... I still wont be able to sleep tonight... but where do i get one? what is it called? Any help would be awsome.... THANKS!
it happens man, i have a spare i think off a stock se-r block i tossed a while back. if you want it just shoot me some money for shipping and i'll go get it from the moms house
on a side note i was putting my upper oil pan on when i rebuilt my engine and as i was going around tightening the bolts up i heard a PING!,so i know the feeling you describe. turns out there was too much rtv in a front cover bolt hole and it cracked the metal but only on the outside so i just jb welded that baby and its still good
I just want to thank you all for such great support, it is so awsome to see what this forum is all about, I never expected anything like this. dxpxe i sent you a private message with my zip, MMotorsports I will keep you posted just in case. THANK YOU ALL VERY MUCH!
you know this forum is the sh*t..seriosuly everyone here has no problems with anyone...and you dudes and chicks lol you all or we all help anyway we can mann i want my se-r back so bad se-r is family...sr20forum is family...
91 sentra se-r (sold)
91 sentra GA16 a work in progress!! gone finally lol
92 se-r totaled but never forgotten...
lookin for a se-r 91-94 hit me up if u got one for sale lol
snafu16 is right I have tried many other forums and this is the only one that I have found that every one seams to have respect for every one. Sentradude I will go ahead and check on things tomorrow and give you details on what I found to leave you with some options.
Hey did you get the message i sent you yesterday? thanks!!
i think i might have one for you...I'll double check
im in phx, az
b14 5sd= vrs 2.5 catback.exhaust/exedy clutch/5th gen hotshot header/jwt ecu/jwt pop/hot shot intake/es motor mounts/fidenza flywheel 9lb/and soon to come 91 cam and pulley!!
SOME TIMES ITS A PAIN IN DA @SS WONDERING IF THAT'S WHAT CAUSING IT!!
o man not like im trying to back out or anything *** i will never use it and you can have it for just shipping but if that guy is in arizona get it from him that just makes it hella easy for you, let me know
also mine if i have it and i think i do, will need a new seal just so you know, its been out of a engine for about 4 years and is probebly dried up
Oh i know... i wasnt sure if you had it or whatever... I payed $20 to get it shipped from NH... I just need one really bad.. and i was gonna put a new seal on it anyways, cant be that much.. But anyways, thanks man!!
Hey man, the guy i was getting it from accidently broke it taking it off... If you have it, let me know. Thanks
