The easiest way would be to remove the pans and the head (if you want to leave the motor in the car). With out removing both it will be impossible to do with the motor in the car.
Well not impossible but I think it would very hard to do. You will need to remove the entire crank (not easy to do in the car). To remove the crank you need to remove the trans, front cover, oil pans etc etc. Now putting the crank back in after will be an even bigger pita...
Take the motor out or pop the head and pans off. Thats the only way i see it getting done.
Mike
