Old 02-23-2008, 03:09 PM   #1 (permalink)
SentraDude
Engine Noise @ 3K RPM ????
So i noticed that i have a noise around 3K, i can tell its comming from cyl #2... You can hear it at idle but its faint or around 3K and you can hear it under load (if i give it some gas). Not a deep noise, higher pitch noise and seems to be coming from the top end. Valve or rod, or......? I know there is no valve adjustment but a bad shim would make that noise? Its definatley upper and it is not the chain.
Old 02-23-2008, 06:08 PM   #2 (permalink)
SentraDude
Checked engine codes and got 11,14,21 and 34 ... 34 is not listed, 11 is crank sensor, 14 is speed sensor and 21 is ignition signal circuit.
Old 02-23-2008, 06:59 PM   #3 (permalink)
vdubya63
Auto to manual in progres
Rocker arm popped off?
vdubya63 is offline   Reply With Quote
Old 02-23-2008, 08:09 PM   #4 (permalink)
SentraDude
I think that would be very loud.. this is just "there" . Is it possible that i need to check the shims?
Old 02-24-2008, 12:50 AM   #5 (permalink)
vdubya63
Pull your VC off and take a look inside.. My rocker arm fell off and suprisignly wasnt that loud so u justmight wanna check in there.
Old 02-24-2008, 12:50 PM   #6 (permalink)
SentraDude
Will do... keep you updated
Old 02-24-2008, 03:15 PM   #7 (permalink)
SentraDude
Ok.. pulled it off and had someone crank the engine for me and everything looks to be in order.. I cant see anything out of the ordinary. Pushed on all parts and moved everything around and nothing is different. Is it possible that I need to check for worn out shims?
Old 02-27-2008, 12:27 PM   #8 (permalink)
SentraDude
come on guys... what do i look for? noise is comming from the top end it doenst sound like the rod, its not the timing chain, what do i look for?
Old 02-28-2008, 10:39 AM   #9 (permalink)
se-riousclassic
the fo do
First, you should look for a camera and post up a video. People can't read your mind.
99 SE-L
91 intake cam/bluebird t25/Calum ecu/370cc injectors/walbro 190/3inch dp/Greddy Catback/JWT PP w/ SE Disc/Prothane mounts
se-riousclassic is offline   Reply With Quote
Old 02-28-2008, 01:55 PM   #10 (permalink)
SentraDude
lol ok.... ill try to put something up.. thx
Old 03-01-2008, 12:52 AM   #11 (permalink)
SentraDude
Ok... So i havent had a chance or a device yet to record the noise... But here is exactly what is happening. When the engine is cool there is no noise. When it warms up there is slight noise at idle, noise is louder around 3K, but is definate upon rev. up. when i unplugged the spark wire from the cyl. the noise went away all together.
Old 03-27-2008, 08:48 PM   #12 (permalink)
SentraDude
You can here it by clicking here.. http://members.cox.net/tadziu1/engine%20noise.wav
Old 03-28-2008, 12:16 AM   #13 (permalink)
SentraDude
Bump i have the recording up now...
Old 03-28-2008, 12:31 AM   #14 (permalink)
blue-ser
banned
Trader Rating: 11 (92%)
i wont suggest revving the engine any further until u know wats goin on..
blue-ser is offline   Reply With Quote
Old 03-28-2008, 12:45 AM   #15 (permalink)
projectmk3
"Boost Before Looks"
Trader Rating: 16 (100%)
yepp ...i agree with bluese-r..........honestly if i was to take a guess ....it sounds to me like a slight rod knock...i could totally be wrong though *shrug*
good luck hope its not a rod knock but do hope you find out wtf is going on...do you a/c?....check the compressor it could simply be the thing making the noise....mine did when i had my integra ..i almost pooped my pants thinking it was a rod or something till i whipped out the stethoscope and touched my engine in places i never thought i would stick it on....lmao wow @ the way that came out lmao
projectmk3 is offline   Reply With Quote
Old 03-28-2008, 09:59 AM   #16 (permalink)
SentraDude
thx... nope its not a/c, i pulled that off. and its clearly coming from cyl #2 just hard to tell if its from around cams or from bottom end... the engine has about 170miles on it... i dont know if i should bother with fixing it or getting a jdm..
Old 03-28-2008, 12:58 PM   #17 (permalink)
GT-R
It's probably one of those valve's taping in cyclinder 2, that's what I heard when forgot to change my oil properly one time....
GT-R is offline   Reply With Quote
Old 03-28-2008, 08:32 PM   #18 (permalink)
SentraDude
any suggestions???
Old 03-28-2008, 08:42 PM   #19 (permalink)
chriscar
merely a flesh wound
chriscar's Avatar
Trader Rating: 97 (100%)
That's rod knock. I know it well.
Old 03-29-2008, 12:40 AM   #20 (permalink)
SentraDude
Ok... so where do i get a bearing kit? ebay? any suggestions?
