Old 03-13-2008, 09:26 PM   #1 (permalink)
Someday it will be done..
Where is the IAC valve?
I have searched on here and used my Chilton manual but I cannot locate the IAC valve on my '93 Sentra SE-R. I just want to remove it and clean it out. I also signed up yesterday to be a paying member so I can download the service manual but apparently it takes a while for that to get set up. Thanks.
robStER is offline   Reply With Quote
Old 03-14-2008, 11:10 AM   #2 (permalink)
Well, I am pretty sure I found the IAC valve but it sure seems difficult to remove. Any advice on removing it? What happened to SE-R.net? It does not seem to be there anymore. Thanks.
Old 03-14-2008, 11:33 AM   #3 (permalink)
[sr20]sean
nvm i just saw that u said it was a '93 so im not fully sure
dcr1d3r13 is offline   Reply With Quote
Old 03-14-2008, 02:45 PM   #4 (permalink)
Nitelife's Avatar
Trader Rating: 20 (100%)
SER.net is dead due to a legal dispute.
IACV is near the oil filter. There are 4 10mm bolts attaching it to the IM. It can be tricky to remove if you have AC.
I'm feeling nice, I found this thread for ya:
http://www.sr20forum.com/sr20de-tech...2Apics%2A.html
Old 03-14-2008, 10:32 PM   #5 (permalink)
Greatly appreciated. I had been searching under under 'IAC' and didn't think to look under 'AAC'. I do have the AC and it seams quite difficult to get in there. I actually have a miss at idle and I don't think cleaning this out will fix it but I want to make sure it is clean. I will be checking my injectors soon and then for vacuum leaks. Thanks very much again.
Old 03-15-2008, 12:02 AM   #6 (permalink)
Nitelife's Avatar
Sounds like you've got a pretty good idea of how to approach the problem. Hope you fix it.
Old 03-15-2008, 12:24 AM   #7 (permalink)
Is it located in the same place on lowports too?
98' 200sx SE-R
- JWT Pop Charger
- High Port Cam
- Gen 1 HS header
- 2" Stromung cat-back exhaust
AutomaticTransJAIL !
SR20WhoKnew is offline   Reply With Quote
Old 03-15-2008, 03:38 PM   #8 (permalink)
working on it
swiss's Avatar
Trader Rating: 22 (100%)
Very close, but even easier to get to.
Old 03-17-2008, 12:41 AM   #9 (permalink)
could someone point out where exactly it is on a lowport or even a picture?
And what can I use to clean it?
Thanks
Old 03-17-2008, 12:56 AM   #10 (permalink)
working on it
swiss's Avatar
It's the exact same part, in the same place. It's just about 6" higher (about where his hand is).
Old 04-07-2008, 11:54 PM   #11 (permalink)
Well, I finally got around to removing the AAC valve and pretty hard to do with all the power steering/AC stuff in the way. Anyway, while I was wrestling it out of that confined space it appeared that a small spring fell to the ground at that time. So I am assuming it fell out of the AAC valve. I included a pic with the small spring circled. I cannot figure out where this goes inside the AAC valve. Any input?
