Old 03-25-2008, 01:59 PM   #1 (permalink)
Mr Sentra
Keeping It Real
B15 SR20DE Tranny Issues
Hey all. Here's what happened. I went driving the car after repairing/replacing the gasket between the manifold and the turbo. The car seemed great at first, with absolutely no issues. MAYBE a little hard to get into first gear. As I was getting off a highway off ramp, I noticed that it was difficult to downshift, but it still would go. Taking off from a stoplight, it sorta grinded before slipping into first gear. I was going to Autozone for some cleaning supplies. When I was leaving, the car really had a hard time getting into first gear and then when I was trying to pull out of the driveway, it would not go into gear at all. I had a few buddies with me, so we attempted to troubleshoot and decided to bleed out the clutch. We did that and it still wouldn't get into gear. I then had the car towed back to my apartment. I also attemped to start the car in first gear and the car wanted to go forward, with me still having my foot depressing the clutch pedal. The car would start fine in neutral, but will not get into any gear. With the car off, the car gets into all the gears fine.
I called JWT a little while ago and was trying to troubleshoot all the symptoms over the phone. The clutch setup I have is a JWT Stage II setup with lightened flywheel. It is about 25k miles old. I don't think it's the clutch, just because for it to go bad, I would think there would be some slipping going on. I was trying to call it the throwout bearing, but I was told that it would be making noise. What does everyone think? I really appreciate any help that would lead me to fix this. I would hate to tow my car to the dealership to fix, but I honestly don't have too much time to work on the car since I'm on sea duty. Thanks again in advance!
Marvin
B15 SE TURBOCHARGED
Mr Sentra is offline   Reply With Quote
Old 03-25-2008, 02:06 PM   #2 (permalink)
Naghebe
Back down to one SR20
Trader Rating: 38 (100%)
It's the clutch, same thing just happened to me, with the exact same symptoms. Mine spit a spring, which caused it to not be able to disengage.
Naghebe is offline   Reply With Quote
Old 03-25-2008, 02:12 PM   #3 (permalink)
Mr Sentra
Keeping It Real
I should go ahead and buy a new one to replace it. And if it's not, then I'll go ahead and return it. So the SAME EXACT symptoms?
Old 03-25-2008, 02:19 PM   #4 (permalink)
Naghebe
Yup... overview:
http://www.sr20forum.com/buying-sell...nd-clutch.html
It would also move when started in gear with the clutch depressed.
Old 03-25-2008, 04:16 PM   #5 (permalink)
Mr Sentra
Keeping It Real
Any possibility that the slave cylinder failing? That's another opinion that has came to my attention.
Old 03-30-2008, 11:27 AM   #6 (permalink)
Mr Sentra
Keeping It Real
Hey everyone! I got the chance to work on the car yesterday with a few of my friends. Come to find out that the clutch disc had failed. It's hard to explain, so I'm going to take pictures later today, but it wasn't the spring, but it was part of the assembly that broke of and got jammed between the pressure plate and the disc. Clutch fork and throwout bearing look good. Did all the work in my garage, so we spent most of the time out getting certain tools and parts we needed. If anyone lives close or in San Diego and would like to let me borrow a 10mm reverse socket for the tranny fill, that would be awesome.
Oh, so is this to be expected for 25,000 miles or less on a JWT Stage II with 1 metal side disc? I mean, I'm kinda worried that I put the setup right back into the tranny just to have it fail again like that. I can't even remember how much torque this is rated at.
Old 03-30-2008, 04:51 PM   #7 (permalink)
jonwepa
Going on motor #3......
Trader Rating: 29 (100%)
Wow my car is doing the same exact thing. I am really hoping its the clutch disc also, which is a nice easy fix.
Thanks for this encouraging post.
Old set-up: 91 se-r sr20de+T 13.04@110mph w/ a t25 and s3's!
New set-up: 91 se-r gti-r sr20det w/ a gt28r. New times when I can get that damn thing running!!!!
jonwepa is online now   Reply With Quote
