Old 04-25-2008, 06:25 AM   #1 (permalink)
$pider
Trader Rating: 0 (50%)
Big hesitation between 4k-5k, what else I can change?
During acceleration at WOT or good acceleration, there is a big hesitation from 4k to 5k ... after 5k boom, it accelerate real good.
I have hard time finding what is the problem...
First I changed the spark, oxygen sensor and gas filter. All those needed to be changed o2 sensor wasn't good any more, gas filter too.
The car have multiple electric too.
What else can I verify or change? Injector, timing, maf ?? something else?
Thanks for your help
$pider is offline   Reply With Quote
Old 04-25-2008, 09:34 AM   #2 (permalink)
MegaSoreAss
I recently have had some trouble with "hesitation" around 3000 rpm. It turned out that the maf was defective. It would work reasonably well at other rpm ranges but ran very rich between 3000 and 3500 rpm. Changed the maf and solved the problem
MegaSoreAss is offline   Reply With Quote
Old 04-25-2008, 04:41 PM   #3 (permalink)
$pider
I will try that, I suspected the maf too cause its painted blue and seem to come from an other car...
I will get you back with it
thanks
Old 04-25-2008, 06:55 PM   #4 (permalink)
mercado se-r
mine has it from 2000 to 3000rmp but the air fuel guage it lean then after 3krmp it runs bettER IDID A REGRUOND FOR THE MAF IT GOT BETTER BUT IT STILL THERE
mercado se-r is offline   Reply With Quote
Old 04-25-2008, 07:17 PM   #5 (permalink)
PwrdByUncleBens
... like as in rice
PwrdByUncleBens's Avatar
Ive made a couple posts about having the exact same problem and I never figured it out. Its almost like hitting vtec lol except its more like vtec with the switch points all f***ed up.
92' Nissan Sentra SE-R - bluebird SR20det woot!
VOTE RON PAUL OR DIE
PwrdByUncleBens is offline   Reply With Quote
Old 04-25-2008, 10:24 PM   #6 (permalink)
mercado se-r
same here it does sound good some times
Old 04-26-2008, 03:32 AM   #7 (permalink)
$pider
N/A or turboed???
Old 05-05-2008, 07:19 PM   #8 (permalink)
$pider
Fixed my problem... the tps wasnt at the right position, shown 4.2 volts at WOT... I twisted the tps to get 4 V and fixed my problem, the car run fu*king good now. Damn noobie that used to work on this car before I buy it.
I never saw a car with so much problem!!!
Old 05-05-2008, 07:54 PM   #9 (permalink)
gomba
Endless Turbo Preparation
hesitation for me was caused by my BPT valve being clogged.
'95 200sx SER - Loading Turbo.exe |!!!!.................| 22%
"He who asks a question is a fool for five minutes; he who does not ask a question remains a fool forever” - Chinese Proverb
gomba is offline   Reply With Quote
