Old 05-06-2008, 08:33 PM   #1 (permalink)
93specv
i learn as i go
gurus/builders???motor too tight???
how tight is too tight (i.e. bearings/crank) ???
i am getting to the final stages of my build, oil pans are on, rockers in, bout to install cams now to button up the top end.
i tossed on the crank pulley and went to turn it slightly just to re-align for TDC to install the cams, gears, and everything else.
it was very difficult to turn, forceful even.
it is a det block, and de head. also vvl head gasket.
arp studs.
everything else is built to spec. i even used the stock grade bearings, as opposed to everyones suggestion of going one grade tighter.
it will be turbo when its done.
help/suggestions/experience please
~leon
BOOST!!!!! coming soon '08
B13 PARTS 4SALE:
http://www.sr20forum.com/mechanical-...arts-sale.html
All Your Local Repair and Custom Needs:
Anthony Q
A&C Imports LLC
(603) 669-2824
e-mail: ant280@aol.com
Old 05-06-2008, 08:37 PM   #2 (permalink)
dxpxe
did you turn it a couple revolutions?
how did it feel when it was just a short block?
was the timing on correct?
dxpxe is offline   Reply With Quote
Old 05-06-2008, 08:37 PM   #3 (permalink)
93specv
i learn as i go
i hear tighter is better than loose for boost.
i also know the effects of expansion from heat.
but i also know the bearings have that groove for a continuos feed of oil.
i dont know. kinda stressed, so close after 2yrs of building to run into issues at the end.
*** reading myself theorize i suppose.
feedback?
Old 05-06-2008, 08:40 PM   #4 (permalink)
93specv
i learn as i go
the timing was correct when i installed the oil pump (ve)
you kinda had to snap the wrench when it was a short block, but then it spun freely.
the chain is still zip tied to the side of the motor holding its place, so no, i didnt rotate it at all.
Old 05-06-2008, 09:26 PM   #5 (permalink)
Nitelife
Nitelife's Avatar
Trader Rating: 15 (100%)
Mine was pretty hard to turn by hand when I had it buttoned up on the stand. You should be alright, man.
Old 05-06-2008, 09:53 PM   #6 (permalink)
93specv
i learn as i go
yes, but, even though the pans are on and head is on....there is no compression just yet, and the chain isnt installed. it should still act like a short block...no?
Old 05-07-2008, 03:50 PM   #7 (permalink)
det-ser92
Slow down? Maybe..
det-ser92's Avatar
Have you got it yet? Do you have the spark plugs in? The cams are out, right?If the spark plugs are in, you will have compression and it will feel like its trying to lock up. You're compressing 2 cylinders at a time since ALL of the valves are shut. If the spark plugs are out, it should feel like it did when it was a short block.
Let us know how it goes. Dont loose your timing though. Your timing chain should have shinny links to i.d. the timing marks.
Good Luck. SR builds are fun
I saw a Lambo once, it was in my rear view getting smaller.. go figure
det-ser92 is offline   Reply With Quote
Old 05-07-2008, 04:30 PM   #8 (permalink)
dxpxe
sounds like your ok, a short block would be hard on the first rotation just from the oil and everything sitting on the bearings but would crank easy once it was moved so you sound good there.
and if you havent rotated it yet and the timing is dead on like you say then i bet your fine. just be aware that though the tensioner clicks out when installed it is a HYDROLOIC tensioner which means if you rotate the engine (and you should) then make sure to keep a good eye on your timing because it CAN jump. Rotate everything slow and see that its working smothly and triple check engine timing.
Old 05-07-2008, 05:23 PM   #9 (permalink)
lynchfourtwenty
SE-R Abuser
ok check this out buddy.. if from what i read if i understand it correctly (i may not) but if your timing chain is NOT installed and your head is bolted on with cams an valves all installed ect. and your spining the crank.. your prolly bending some valves... i've never tore apart an sr motor an tried this.. but i know on my datsun l20b motor and toyota 22r motors if you have the head bolted on an no timing chain an you spin the crank it will bend valves for sure.. just a thought man like i said i might not be correct an may not understand these motors as well as the rest of you guys.. but i've seen it happen on other motors.
also if the chan is installed on the crank sprocket it could be binding up aswell.. had that problem on a ka24de
good luck man!
91 se-r engine swap in progress
92 se-r wrecked an bein stripped
92 e/xe or whatever 1.6 auto (gf's whip now)
77 datsun 620
lynchfourtwenty is offline   Reply With Quote
Old 05-07-2008, 05:29 PM   #10 (permalink)
Loek
Flying Dutchman
As far as I understand, no cams are in yet ?
Loek = Luke
Nissan Primera WP11-144, DV9, CVT, SS exhaust 2,25', Ign.Timing 17 Deg. Advanti AEM Autometer Blox Bride CS-BABK D-1 ES Flexalite Greddy HKS Intrax Koni Magnaflow Momo NGK Nismo Optima PIAA Progress Raptor Remus Sachs Samco Sparco SSAC Stillen Taylor Toyo Walbro Wilwood
Loek is offline   Reply With Quote
Old 05-07-2008, 05:41 PM   #11 (permalink)
lynchfourtwenty
SE-R Abuser
ok ya he's About to install cams.. well like i said i may not have read it correctly.. im not dislexic but sometimes it seems like it
so i guess the only other thing i can think of is if he has the chain attatched to the crank sprocket it could be binding up.. other then that idk
Old 05-08-2008, 12:19 AM   #12 (permalink)
93specv
i learn as i go
the spark plugs are not installed yet.
the cams are not installed yet
the timing is set per the FSM at the marks starting with the one on the oil pump/crank gear
was getting to the cams when i went to line up the crank at TDC as it had moved slightly when installing the pully.
this is where i ran into the issues.
this build "is" fun, i've learned a great deal thus far and continue to learn!
yeah, like i said, when it was short block i just kinda "popped" the crank with the wrench on it, then it spun fairly easy.
no longer the case.
i read about the tensioner in the FSM, thanx for the heads up.
once all is installed, i will count links to check that all is timed! 4sure!!!
that is correct my good man!
dude, im a little slow some times too. no worries.
thanx for the vote of confidence!
Old 05-08-2008, 12:37 AM   #13 (permalink)
lynchfourtwenty
SE-R Abuser
ya dude you'll get it, then you'll be rollin around all happy like.. take pics!
Old 05-08-2008, 01:15 AM   #14 (permalink)
93specv
i learn as i go
progress pics here:
http://www.sr20forum.com/members-rid...o-project.html
Old 05-08-2008, 01:20 AM   #15 (permalink)
lynchfourtwenty
SE-R Abuser
NICE!
Old 05-10-2008, 01:07 AM   #16 (permalink)
93specv
i learn as i go
well, after alot of discussion, some research, more discussion and research... i concluded i needed to disassemble the bottom end loosen and re-torque the crank bolts.
the FSM states on DET application, if an angle wrench is not available then after initail "stretch" torque, again torque to 62-84 ft lbs.
i started at 62 which was too loose and worked my way up, ending at 73 as a desireable torque in reference to ability to turn the crank.
i hope this is ok as i am using ARP studs, and 80 was too tight.
im am still uncertain to what they were torqued to, and dont know how they got so tight, but all seems well now!
Old 05-10-2008, 03:57 AM   #17 (permalink)
lynchfourtwenty
SE-R Abuser
nice mang good to hear
Old 05-10-2008, 12:40 PM   #18 (permalink)
Mike I am a moderator
_______
Mike's Avatar
Trader Rating: 51 (100%)
Leon,
Go to Autozone and get one of those angle wrench things. I got one for myself and it was < $20 (I still have it if you feel like coming by and picking it up). All it really is is an adapter that goes between the breaker bar and the socket. You snap it on and give it a reference point then crank the bolts down. It's a must for doing any bolts in the bottom end of the block.
Also so you know the bottom end is going to be considerably tighter than it was before you freshened it up. It should turn but you have to think the bearings need a break in period for a reason (to break them in.. hehe).
Get an angle wrench and loosen everything up then torque it down correctly and see where you stand.
You have my number if you want to borrow mine.
Mike
Mike is offline   Reply With Quote
Old 05-10-2008, 12:45 PM   #19 (permalink)
_______
Mike's Avatar
hehe.. NM my last post. So what did you do? Loosen it and then tighten it back up?
Mike
Old 05-11-2008, 02:39 AM   #20 (permalink)
93specv
i learn as i go
