Adjusting valves or lifters.... - SR20 Forum
Old 01-08-2009, 04:09 PM   #1 (permalink)
Trial 'n Error Automotive
Whats up everyone, im in need of some help with my sr20. i have a slight clicking under the valve cover,it doesent sound like a valve tick(not tht bad of a noise) but i dont know exactly whats making the noise, and i do know its not my injectors(just to get that out of the way) any way my buddy has an integra wtha b18, he had the same problem and his rememdy was adjusting what i think was something to do witht he valves or lifters, im not sure. what i would like to know is if this is possible to adjust on our cars and if so how?
i have searched but got nowhere.... thank you
Wesley
Working with Gspec. Saving my beans so i can fly to Cali and chill with The Greg man.
White '91 Se-r: Burns oil, Rear quarter crushed in, For Sale $800.00 obo.
novadose914 is offline   Reply With Quote
Old 01-08-2009, 06:54 PM   #2 (permalink)
Konichiwa
What you're descibing is basic valve train noise.
You most likely need to adjust the valve lash on a few of ur valves but I wouldn't reccomend doing so unless the motor has 150k+ miles.
The_7_Cant_Lose is offline   Reply With Quote
Old 01-08-2009, 07:06 PM   #3 (permalink)
Whew!!!!! but any way how would i go about adjusting this, is it just like a honda? an allen key or somethiogn like that?
Old 01-08-2009, 07:44 PM   #4 (permalink)
Konichiwa
check the fsm. should give you a good idea on exactly what ur doin
Old 01-08-2009, 07:53 PM   #5 (permalink)
**** sound like a newb but FSM... is that like like a haynes manual or chiltons?
Old 01-08-2009, 11:50 PM   #6 (permalink)
Konichiwa
FSM=Factory service manual.
It's what the techs at the dealership use to work on ur car.
Old 01-09-2009, 12:42 AM   #7 (permalink)
SR20DETERMINED
Feedback Score: 17 reviews
ok all this bad info going around i just cant stand it anymore.
For one the SR20 is a hydrualic lifter motor. In other words it does not require valve lash adjustment. The lifters do it for you.
Two: the sr20 is known for being somewhat of a ticky motor.
Three: Basics that you can do is install a new timing chain tensioner with a updated one.
Four: If the noise is excessivly loud at all times then you probably have a bad lifter in that case it would require pulling the cams out and putting new lifters in and bleeding them when doing so.
Five take care of the motor and it will take care of you.
And further more the hondas have adjustable lashes on their valvetrain but they do not use hydraulic lifters the rockers have adjustments to close the lash after wear occurs.
Again if the noise is not excessively loud dont really even worry about it. Use good oil and a good filter, change at least the tensioner to keep chain noise to a miniumum. Good luck with the motor. All these replies and no good correct info. Search, Search, Search is your friend. There is probably 100 threads or more on this stuff.
92 Nissan Sentra SE-R
Fully built SR20DET, JWT S4 cams, 720cc injectors, Calum Basic ECU, Fidanza Flywheel, ACT extreem clutch, mezier electric water pump, Garrett t3t04 60 trim turbo w/ a .82 turbine housing, ebay tubular manifold, tial 38mm wastegate, All work done by me
ashtonsnissannx is offline   Reply With Quote
Old 01-12-2009, 06:31 PM   #8 (permalink)
Parts hoarder.. hehe
Feedback Score: 21 reviews
haha! I was wonering if someone that knew whats up was going to chime in.. lol.. good job Ashton *pats on back* .. lol
Need to work on my 60' but here are the times,
Best time- 13.74 @ 103.8 mph
Best trap- 13.84 @ 104.4 mph
Psst! is offline   Reply With Quote
Old 01-12-2009, 09:13 PM   #9 (permalink)
from FrontWD to RightWD
Feedback Score: 6 reviews
reading the first few posts i just started to laugh lol.
like ashton said, no need to adjust the lifters because they are all hydrualic.
unless you have a gti-r, because i guess they have solid lifters
Old 01-12-2009, 09:17 PM   #10 (permalink)
merely a flesh wound
chriscar's Avatar
Feedback Score: 110 reviews
It's the blind leading the blind. I started to reply the other day, but it was too nasty to post, so I just shook my head and moved on.
Old 01-12-2009, 11:02 PM   #11 (permalink)
well, i had no idea these had hydro lifters thts as why i was asking, as for those who responded thank you, even those of you who tried but failed.
Old 09-02-2009, 01:12 AM   #12 (permalink)
I'm having the same problem but with a gtir motor, lifters are not hydraulic but are solid, definitely lifter noise...any remedies?
donniepersad is offline   Reply With Quote
Old 05-05-2010, 10:13 PM   #13 (permalink)
HEY MAN I HAVE THE SAME PROBLEM
CAN ANYONE HELP US
FERCHO2583 is offline   Reply With Quote
Old 05-06-2010, 06:46 AM   #14 (permalink)
think about it solid lifters where is your adjustment! lmao probs need replacing if your motors have done a few miles but these can be adjusted
i can fart using just my shoulder http://www.sr20forum.com/images/smilies/biggthumpup.gif
honda prelude dead
toyota corolla dead
nissan sunny n14 1.4 turbo dead
peugeot 205 gti dead
rover 214 turbo dead
nissan micra 2.0l dead
nissan 200sx s13 turbo still alive but sold
nissan sunny van dead
peugeot 309 gti mi16 dead
peugeot 205 1.4 rally car dead
ford f150 now my dads
sr20bud is offline   Reply With Quote
