ok well according to JGY's site, their flywheels DO NOT throw a SES light. I on the other hand am experiencing one. I know that the reason is because of the teeth on the flywheel. im guessing the JGY FW has 109 teeth on it, & my 96 G20 needs the 108 teeth one (not sure on that statement, but pretty sure),
also not sure if the tooth thing is a issue, supposedly the crank position sensor is a magnetic sensor of some sort...could it be that all these flywheels that trip the light aren't made out of a matl. that picks up/generates a correct magnetic fields?
which sensor determines this? is it the one in the front of the bell housing? is it the starter? how does it determine it? does it count the teeth? or is it a magnetic thing?
what im looking to do is somehow trick the ECU into thinking the flywheel is correct.
im guessing that the voltage from the sensor is different when you have a 109 tooth wheel in there, but needed a 108. & vice versa.....so if someone could find out what the voltage should be & post it, i could then check mine & figure out how much its off by, & then either wire in a resistor, to lower the voltage, or wire in something to increase the voltage..therefore it would eliminate the need for people to worry about wich FW to buy.
Also if someone could...please post which FW's are needed in which car (i know there was a thread before but i cant find it.)
b13 =
b14 =
S13 =
S14 =
p10 =
p11 =
now this may seem like a stupid endeavor, but i swear it is not....the problem i am having is, my light is on, & my PA inspection is up, & in PA if ur light is on, that equals a automatic fail.
So please please please!!!! try to help best you can.
