Transmisson help, please... - SR20 Forum
Old 04-14-2009, 01:27 AM   #1 (permalink)
Nobody pays me in gum
Feedback Score: 12 reviews
I have had it with working on this b15 transmission. I bought a non-lsd, low mileage trans. from a reputable seller on this forum and after receiving slim to no help from them, countless hours reading, and asking any local people if they had any ideas I am still stuck with the same thing.
It will NOT go into gear while off or while running. If I let the clutch out it moves forward, but if you look at or shake the gear shift it feels like it's in neutral.
The stabilizer and shifter rod have been ground down enough where I can fit my hand in between them, but you can't shift anyway so I know those aren't binding. Both the stabilizer bushings have been replaced with the E.S. polyurethane inserts. The clutch cable is brand new, along with OEM TOB and clips. I have the correct axles for it, the tranny saver bracket, and the clutch/flywheel setup was working fine when the b13 trans was pulled. The trans. was converted to a cable and didn't seem to exhibit any problems before it was installed.
I don't hear any noise coming from the trans. at all from when I had it running. I have tried playing with the clutch cable, but it did not make a difference. Forgot to mention the clutch is a ACT xtreme with 6 puck unsprung disk.
Any help is GREATLY appreciated because this car has been down a while and I need it to be up and running again. Thanks.
Red 92 Sentra SE-R.
Originally Posted by Shawn B View Post
How come upgrading one part means upgrading other things, which requires further upgrades to the things attached to the original upgrade?
MN_SR20 is offline   Reply With Quote
Old 04-14-2009, 11:44 AM   #2 (permalink)
Feedback Score: 11 reviews
Have you tried to see if it will go in gear by hand by grabbing where the shifter linkage hooks up?
94 Sentra XE aka "the Traski" Rest in Pieces
97 200sx SE-R
hiimrif is offline   Reply With Quote
Old 04-14-2009, 04:00 PM   #3 (permalink)
no, but i will go out right now and try it. disconnect the linkage from the trans. or from the shifter in the car, or both?
Old 04-16-2009, 09:44 AM   #4 (permalink)
Nitelife's Avatar
Feedback Score: 46 reviews
I would have suggested this too. You can just undo the linkage where it connects to the tranny and then grab that part with the boot and move it to engage gears by hand. That will at least let you know if everything is alright inside the gearbox.
So did you get to check it MN_SR20?
Old 04-16-2009, 07:39 PM   #5 (permalink)
but young at heart
Feedback Score: 9 reviews
One of your shift forks is likely busted. Happened to me on a '92 Eclipse Turbo. Only way to find out is to open up the case.
"I am the gatekeeper of my own destiny and I will have my glory day in the hot sun." - who said that?
oldman is offline   Reply With Quote
Old 04-16-2009, 09:50 PM   #6 (permalink)
what could cause the shift forks to break? if this is the case.
and if it is then miko sold me a busted b15 trans he said was good, i'll be looking into it...
how easy are they to replace IF that is what happened? I only looked at the inside of my b13 trans once and I don't remember much of it.
Old 04-16-2009, 11:07 PM   #7 (permalink)
but young at heart
Well, verify it before you proceed for sure. I hope for you that it turns out to be an easier fix.
Old 04-16-2009, 11:19 PM   #8 (permalink)
Me too, but with all the suggestions I got and none of them working. I am going to be upset having to pull it again.
Old 04-17-2009, 07:33 PM   #9 (permalink)
I tried doing it by hand but to no avail. same thing happens like the shifter is connected. Does it look like the only reasonable solution is to open up the case and take a look?
Thanks for the help guys, the only help i received from miko was i installed it wrong, because he claims it was perfect. It came out of a t-boned sentra with low miles.
Nitelife I'm sending you back a PM right now
Old 04-18-2009, 12:12 AM   #10 (permalink)
what town ya live in?? i also live in minnesota.
nx2000_guy is offline   Reply With Quote
Old 04-18-2009, 11:39 AM   #11 (permalink)
_______
Mike's Avatar
Feedback Score: 57 reviews
When you tried to shift it into gear by hand did you disconnect the linkage first?
If not give that a try and see what happens. That way you can narrow it down. As someone stated above it is most likely the linkage. I know when I helped put a b15 trans into a b13 it took a bit to get the linkage proper. Come to find out the linkage bar was bent just a hair and it threw off the entire gear throw (almost hitting the drivers seat in 2nd).
So if your linkage is bent it will definitely interfere with shifting even if your trying it by hand under the car. Disconnect it and give it another go and see what happens.
Mike
Mike is offline   Reply With Quote
Old 04-18-2009, 12:19 PM   #12 (permalink)
Blaine
Mike
I did disconnect it from the trans. and I took a vid of it. it kinda sucks, but here it is. it sounds like it wants to go but just won't it clicks like it does want to though
As far as the linkage being bent I don't think it is because the car shifted and drove just fine before this swap. However if I can't solve the problem I will look into the B15 shifter rod and stabilizer.
Old 04-18-2009, 12:23 PM   #13 (permalink)
Does anybody know where I could find any specs or measurements of the B15 clutch arm in case the conversion to cable was my problem I want to have the cable armed machined to look exactly like the B15 arm.
Here are some pictures of how I ground down the shifter rod and stabilizer. For reference I can fit my hand between the 2.
Old 04-18-2009, 03:03 PM   #14 (permalink)
sounds like your shift forks if ya ask me.... you ever go to uni?
Old 04-19-2009, 11:05 AM   #15 (permalink)
so now that's 2 votes for it being the shift forks and also to check the TOB and clutch arm. I guess my only option is to pull it again and open up the case. I'll try to pull it today and get pics up of what I am looking at.
nx2000_guy, if you haven't seen already here and on the dash in the midwest section there is a thread for the minnesota/university area. I do go down there a bit, but so do plently of other guys you've probably seen. I just didn't want to clutter up this thread with stuff not related to my transmission.
Old 04-19-2009, 02:13 PM   #16 (permalink)
I got the trans. out of the car and I am in the process of taking pics/video of what I encountered... I am anxious to find out if what all of you said is true.
Old 04-19-2009, 03:02 PM   #17 (permalink)
Here's how it looked when I opened it up
Nothing wrong here right?
Is this as far as the TOB moves forward? If I push the TOB past that sleeve it centers on it won't come back sometimes because it gets misaligned or it rotates and the clips come off the pins on the clutch arm.
And lastly I have a video of trying to shift gears. How hard should it be to get into gear?
Old 04-19-2009, 07:56 PM   #18 (permalink)
but young at heart
It shouldn't be too hard to shift into the gears. I could do it with my bare hand just prior to installing my tranny.
Try opening the case and look at the shifter forks.
Old 04-19-2009, 10:06 PM   #19 (permalink)
I'm not too sure what I am looking for and I am not too familiar with what everything should look like, but here are some quick pics I snapped. Let me know if I should check something or take pictures of something else to help diagnose the problem.
Old 04-20-2009, 12:10 AM   #20 (permalink)
but young at heart
Ok, you mentioned when you let the clutch out that the car moves forward, so that means you are in gear. But which one?
I borrowed your pic for some illustration. The red arrows point to the shift forks, make sure they aren't broken within the circles marked yellow. If they are not, look for other metal shavings anywhere else within the tranny assembly.
