Originally Posted by sharmon
1995 200SX SE-R. The car runs great, however, there is a hesitation at low RPM's (sub 2K range) in 1st and second gear (at least). It is a 5-speed manual. I have two codes: p0304 and p0608 (knock sensor and cylinder misfire #4, I think). Anyway, I've replaced: plugs/plug wires/cap/rotor/air filter, fuel filter, oil, oil filter and coolant (and the clutch). My fuel economy also seems to be below normal (as in below 20, by my estimation). The spark plugs on all four cylinders were a beautiful golden brown when removed. The car idles and cruises normally. The hesitation ONLY exists from 1-2K (doesn't matter if it's under load or not). Any thoughts, guys? I'm thinking perhaps a leaky injector, which may be flooding the cylinder a bit at the low RPM's (when less fuel is required). The engine sounds very, very healthy (no audible knock/lifter noise/etc). Thanks!!!
I'm having the exact same issue with my '92 classic. The car was meticulously maintained by the original owner with 100% Nissan parts.
A bit of a rough idle, smells like it's running rich at idle and a slight miss at 1-2k RPM's, gas it and it goes away. Runs perfectly otherwise. New cap, rotor, OEM NGK's and NGK wires. Old plugs looked perfect with about 35k on them. Gas mileage is in the 20-22 mpg range around town and I drive like an old man (my wife can verify this
). The mileage seems low compared to the other SR20 powered vehicles I've had.
No CEL, but I haven't tried to pull codes yet.
