b13 RR Swap - SR20 Forum
Old 01-09-2010, 04:40 AM   #1 (permalink)
b13 RR Swap
Hi Guys,
I'm just new here and i hope i'm welcome. I'm from the Philippines by the way I found the posts here very informative. But still i have questions and i hope i'm sending out the right ones.
I'm in the process of swapping my sentra b13 GA13ds carb engine to a non LSD manual SR20de RR and its not a walk in the park for me. Got the engine complete with it's sensors, ECU and the wiring harness is not badly cut by the salvage man. but the thing is it's missing both axles.
here are my questions:
1. what pair of axles should i be using? are the high/low ports and RR have the same axles in the sense that they are interchangeable?
**** I will be using the stock wheel hubs of the GA13 but with ad18v calipers and rotors and the pcd of the hub is 100.
2. what would be the part numbers for the axles coming from the 91-94 sentra se-r's? will they fit in the pcd 100 wheel hubs?
I do not know if this is the right for me
http://www.oreillyauto.com/site/pi/d...V0&item=606032
3. can anybody give me a wiring diagram of the RR?
please help. thanks!
4banger is offline   Reply With Quote
Old 07-23-2010, 09:10 PM   #2 (permalink)
Originally Posted by 4banger View Post
Hi Guys,
Your gonna have to get 2.0 hubs or or change the hub end to 1.8 the transmission end has to be 2.0... thats what i did just a temp fix till i get some 2.0 hubs...
DocStrange is offline   Reply With Quote
