Speedometer / Tachometer actin funny, help please! - SR20 Forum
Old 04-06-2010, 12:40 AM   #1 (permalink)
Ok so i posted this up on my other thread, but failed to get any answers. So here's the problem.
My tach doesn't work, at all. I've removed the dash, checked the wiring into ECU as some threads/websites state. Everything looks fine. Is there any other wiring for this? Perhaps into distributor?
My Speedometer acts weird, sometimes it doesnt work at all. And other times when im lightly driving in and out to move the car around for others, the speedometer jumps to 60-65 mph, but the tach still at 0.
I'm going to check the Speedometer cable on the tranny tomorrow, as i figure thats the culprit for that. But tach is confusin the hell out of me
slor is offline   Reply With Quote
Old 04-06-2010, 02:18 AM   #2 (permalink)
going thru life @ 1 bar
Feedback Score: 21 reviews
mechanical speedo or electric?
...Currently down due to a clutch disc spring failure....
Old 04-06-2010, 10:39 AM   #3 (permalink)
analog
Old 04-06-2010, 11:26 AM   #4 (permalink)
The signal for the tach comes off the coil. so its either wiring or bad tach causing that.
and check your speedo cable and see if its plugged tightly into the speedo. if it is, remove it and check to see if the cable is broken. if its not, its either the speed sensor, or the speedo gauge itself
Old 04-26-2010, 08:15 AM   #5 (permalink)
tach error
what type of engine is it you got and make of car sir?
fosterr is offline   Reply With Quote
