Total Noob - SR20 Forum
Old 04-22-2010, 10:11 AM   #1 (permalink)
Total Noob
Whats the easiest way to relocate the Battery without buying a kit? and I can't seem to find (again) a cross reference sheet for oil filter, plugs and other things like that, can anyone help? Thanks Josh
drspydr24 is offline   Reply With Quote
Old 04-22-2010, 12:00 PM   #2 (permalink)
sr20s are my crack
it sounds like its some trailerpark stuff but you can get some jumper cables and run them back the car like some amp wires and hook them up that way lol. the oil filter number is something you can find at autozone or something along the lines and i normally get some NGK bkr6e or 7e
boosted b13- sold
1998 200sx se-r, cat back apexi n1, air filter, and nology hotwires. sold
srt4 swapped 98 neon sold
5spd p10 sold
94 XE-R GTiR- sold
searching for my next b13
trbob13 is offline   Reply With Quote
Old 04-30-2010, 05:20 AM   #3 (permalink)
Buy some battery cable from napa, inbolt your old battery tray and screw it down in the trunk and run your positive to the trunk, dont forget a fuse so your car wont burn down if you get a good short.
PDX_SER is offline   Reply With Quote
Old 05-03-2010, 11:02 PM   #4 (permalink)
Noobish..
I vote for the jumper cable extension - it's doable as long as you use the right connectors and crimp them on VERY tight, insulating them well in the process. You also want the same gauge wire as the battery cable... not something much skinnier.
One thing to consider is weight balance when doing this mod. The engine is the heaviest component, and it's on the passenger side. The battery is there to help counterbalance the motor so that the car doesn't dip to one side. If you relocate the battery, it would be wise to also relocate the coolant reservoir and whatever else you can to where the battery was.
1996 200SX SE-R 5speed, 220k, totally stock.
neptronix is offline   Reply With Quote
