Hey guys,
I recently got a 91NX2000 from a fellow member, and I already love it. The issue I am having is that there is a lack of power all across the RPM band. I can floor the gas, and it takes awhile for the car to get up and go. It seems like it takes 20 seconds or so to get from a stop to 40-50 mph. It doesnt appear to be a slipping clutch at all. The car could possibly have bad fuel because it sat for awhile, and wasnt driven much. I have changed the spark plugs with NGK plats, the distributor cap/rotor. I noticed today that when i leave the engine running and pull the 2nd spark wire, and the 4th, that no change occurs in idle. If I pull 1 and 3, the engine bogs or wants to die. I can hear a "spark" on 2&4 at least when the boots touches the plug inside. Does this seem like two faulty injectors, a bad fuel pump possibly, or could it be a bigger engine issue? Any info/tips to help diagnosis would be greatly appreciated...Thanks guys !!!
Proud owner of a 91 Sentra SE-R and a 91 NX2000
