HELP! By pass inhibitor switch - SR20 Forum
Old 04-24-2010, 12:05 PM   #1 (permalink)
So on my B14:
I need to know how to bypass my inhibitor switch. Did an auto to manual swap in my 96. Went from Auto GA16 to SR20DET. I can not get the starter to engage so could someone enlighten me on how to get the car to think it is in neutral or park so it will start? Need some help fast.
I have searched and searched....Thanks in advance!
maynardmax08 is offline   Reply With Quote
Old 04-24-2010, 10:32 PM   #2 (permalink)
Feedback Score: 3 reviews
There should be a connector that went to the gear shift on the auto. You need to hook the green/orange wire to the black wire. They should be next each other on the connector. That will be the same as having the auto shifter in park.
I got this from the FSM so be carefull as I have not actually done this myself.
obewan is offline   Reply With Quote
Old 05-08-2010, 11:17 AM   #3 (permalink)
thanks sir!
Old 09-30-2010, 12:59 PM   #4 (permalink)
Do you happen to know the colors on a b13 or NX2000?
beef7567 is offline   Reply With Quote
Old 09-30-2010, 02:31 PM   #5 (permalink)
B13
For an SR harness: Black / White and Black / Yellow
For a GA harness: Black and Brown / While
You should find a 2 pin connector on the shifter for the SR and a 4 pin connector for the GA.
