Installed new alternator car won't start, just SINGLE CLICK - plz help - SR20 Forum
Old 04-29-2010, 08:45 PM   #1 (permalink)
Solved Q/A
Issue was with the oil stick not being in its place.
I hope they have SR20s in heaven
ak_47 is offline   Reply With Quote
Old 04-30-2010, 05:14 AM   #2 (permalink)
The single click sounds like its the starter, try banging on the solenoid while somebody tries to crank it over. Check to see if you have power to your fuses, you could have blown a fusible link if it has them. You did have the battery disconnected before you tried to replace the alternator right?
PDX_SER is offline   Reply With Quote
Old 05-06-2010, 09:43 PM   #3 (permalink)
make sure you connected the pig tail right some times it lets you flip it to where power gets ground and you blow the 7.5 fuse in the box marked alt
(\__/)
(O.o )
i wanna go fast is offline   Reply With Quote
Old 05-06-2010, 10:06 PM   #4 (permalink)
SE-R Joe
Feedback Score: 14 reviews
Originally Posted by ak_47 View Post
1998 Sentra SE
My brother-in-law helped me install a new alternator to replace the broken one but now the car won't start or lights won't come on at all. Just a single click when I try to turn the key...
Battery is fully charged, fuses are ok would you know what might cause this? If you do please help.
Thanks.
Battery is Dead. It didnt take the charge. try jumpin it
joe92ser is offline   Reply With Quote
