yea..guess what i found, 2 valve cover bolts(top right and bottom right) on that side where I'm here the noise where broken for some odd reason.I was goin to take off the valve cover when I noticed that those bolts just came off and I was like what the hell..so I ordered the older style valve cover bolts and a new gasket. I'm guessing its vibration from the valve cover. we will see on monday...
yeah thats weird dude has someone over tightened them cause they shouldnt break on there own and you will probs have to drill the other halfs out if they have snapped keep us posted anyway mate
honda prelude dead
toyota corolla dead
nissan sunny n14 1.4 turbo dead
peugeot 205 gti dead
rover 214 turbo dead
nissan micra 2.0l dead
nissan 200sx s13 turbo still alive but sold
nissan sunny van dead
peugeot 309 gti mi16 dead
peugeot 205 1.4 rally car dead
ford f150 now my dads
i think a friend who was helping me with the cam install over tighten them.I looked and only one has to be drilled out, the other one came out with a really small flat head and I just turned it until I could get it with my fingers.
I'm just waiting for the gasket and bolts to come in then we will see. I will re check the torque on the cam bearing caps, cause it also happen to my 240sx, but the noise was way way louder.
Bump...Update. Fixed the valve cover bolts that were broken. Re-torqued all the cam bearing bolts and fixed all exhaust leaks. Still getting the same noise.
yup.checked everything.and had a friend who is a tech at nissan check it out.Hes confused. For sure, its not a rod going bad or a valve getting bent or something.he believes something is hitting something else which is causing the knocking noise.So, he suggested me to re install the header and see what happens and I should re-check the torque on the header bolts cause it might be vibrating against the head which I won't be able to do until tuesday since its my day off from both of my jobs
i very much doubt it will be the header vibrating mate even if it was loose you would know believe me i think you have one strange problem there dude and i would dig around for a bit more advice
Yea. On tuesday I will put the car on jack stands and go underneath it and inspect everything while the car is running. Because its loud only in certain areas. and most of it sounds like its coming from underneath. I just now thought of Maybe an bad exhaust leak?Cause I am experiencing bad gas mileage.240miles a tank with no hard driving and keeping the Rpms below around 3200. And this happened before I did some major mods. When I bought the car it was perfect and getting 400miles to a tank and thats mix driving hwy and city and some hard driving. I don't want to believe my mods will lower my mileage that bad. I have camshafts,header,2.5exhaust and a jwt pop charger.anyways, well see on tuesday
yeah check it dude ive just had a similar problem to you but the whole engine just packed up now ive got my head half off and i cant see anything wrong with it yet but i hope when i pull the head completely off its something simple but it started with a sound similar to what yours is making dude il keep ya posted on what it is when i find out as well bud
