antifreeze leak? - SR20 Forum
Old 05-23-2010, 11:41 AM   #1 (permalink)
antifreeze leak?
I got home from work this morning and smelled antifreeze. So I looked under the ca and saw that I was leaking antifreeze. not bad but a fast drip. it was dripping off the front cross member and steering rack. it looked like it was a little bit running down the side of the trans on that same side. my guess is something on driver side of motor leaking. I am planning on jacking it up and looking a little better to see what I find. was just trying to pick some heads before I climb under there. here are some pics of the dip area. these are pics from the driver side.
this one is on the steering rack and u can see where it has gotten on it.
it looked like there was a few drips on the rubber boot
95 240sx
sr20det motor swap
240sxfamily.com
95_sr20det_240 is offline   Reply With Quote
Old 05-23-2010, 02:53 PM   #2 (permalink)
Noobish..
Since it's all over the place... clean the engine bay up first, then run it around for a few minutes. It will be obvious.
I mean, it really can come from anywhere.
My friend's BMW had a completely soaked transmission... we thought it was tranny fluid.. no, it was coolant that was being sprayed at an angle, lol
1996 200SX SE-R 5speed, 220k, totally stock.
neptronix is offline   Reply With Quote
Old 05-23-2010, 05:49 PM   #3 (permalink)
k thank
Old 05-26-2010, 12:50 PM   #4 (permalink)
Drivin' my life away. . .
Water pumps usually have a "weep" hole on the bottom so that antifreeze will start leaking out when the seal on the pump starts to wear. That will usually leak only when the engine is running.
"If everything seems under control, you're just not going fast enough." - Mario Andretti
Old guy is offline   Reply With Quote
