injector problem - SR20 Forum
Old 06-18-2010, 05:39 PM   #1 (permalink)
injector problem
I was having problem with a cylinder not firing. put a new injector in the third cylinder, which is the one that was bad. Worked great for a little while. then it started running on 3 cylinders again and I pulled the injector and the o ring was falling apart and the little hard plastic piece above the o ring was warped into a wavy pattern. figured this was my problem and swapped the pieces off off the old injector and worked great. Here I am a couple of hours later and it wasn't working again. Pulled the injector and guess what? The same thing happened. The o ring is shot and that plastic piece is all warped again. Any ideas on what could be causing this?
thanks.
bizkidd05 is offline   Reply With Quote
Old 06-18-2010, 07:05 PM   #2 (permalink)
A short in the harness could cause the injector to heat up and damage it. I dont know, try back probing the wires and see what you come up with. Im having injector problems also welcome to the club.
xavi1320t is offline   Reply With Quote
Old 07-19-2010, 03:06 AM   #3 (permalink)
replace the o-ring and then coat the ring with new engine oil. coat both o-rings with oil. i ran into this problem before. remember engine oil.
wooby782 is offline   Reply With Quote
