b13 with b14 hiport sr no spark
hello i did a motor sway in a 91 ser with a motor out of a 96 200 sx i have a 92 distrib , coil, power transistor, and harness i have power to the coil and power at the power transistor and power to the distrib but when i go to test distrib when i rotate the shaft (connected to harness with cap on removed from vehicle) the fans whil click on and off but if i rotat the shaft fast the fans stay on does any one know wheather i might have switch a connector or some thing any feed back is something thanx
94 four door ga (sentrica) rip
93 sentra se+r (frankenstien) missed cj's repo bitches
92 sentra ser (grandpa) rust bucket indisructable stripped
91 sentra ser mint det (in the works fresh spring build)
97 all black max crashed stripped and salvaged
93 ser the patient and im the doctor (custom build)
1988 k1500 the work horse
97 max 5spd sittin clean
91 civic hatch, its a honda!
