ok.. im having a few issues with my 200, it has a bb det swap w/ z32 maf, 550cc injectors, walbro fp.....
Problem #1:
-once the car has been warmed up and driven for a while, when i depress the clutch the idle drops off and stalls or nearly stalls *
it only does this when the car is hot*
i took out the maf and cleaned it with contact cleaner and replaced the air filter, still doing the same.
Problem #2:
-this issue just started the other day... i go for a drive, car starts fine..then i stop somewhere and shut the car off, when i go back to leave the car is flooded, ive been having to pull the fuel pump fuse and turning it over till the flooding is resolved... then it fires right up
if anyone can shed some light on these issues it would be great!
thanks
Rockett
