ok i have a 1971 hillman hunter with an s14 sr20 set conversion , my car was having idel problem where id doesnt want to hold idel would start normal but then die over time, anyways i though it might the air flow sensor so i pulled all cold air intake off and it was clean and no issues , though possible a fouled plug pulled them all out nothing , anyways i noticed a hose that was sucking on the injector side of the motor comming off the intercooler piping just sucking open air .. , next to this is the hose that comes off to my boost gauge , when i block this hose that is sucking with my finger all problems go away what is this hose and is it ? and is it ment to be connected somewhere ?
Reason: mistakes
