OK, I've done searching an nothing takes me me in particular to this problem. Maybe I haven't searched hard enough but the guess work is already hard.
Just installed a new U13 DET engine nothing fancy just reinforced block all stock. I used my old DE/VE harness on it.
The probelm is the car won't rev when I step on the gass or open the throttle. Another issue is that when I use my DE box it idles until I open up the throttle but when I use the u13 ecu it won't even start up.
I've changed different MAF, and did the trouble shooting sticky, I also changed ignition coils and checked ground wires. Fuel press is ok, plugs are ok too.
Help please, thank you.
