need help please! b14 auto tranny into auto p10. drivers axle problem! - SR20 Forum
Old 08-18-2010, 01:51 PM   #1 (permalink)
intalling 96 200sx ser auto tranny into 96 auto g20. i ran into 2 problems. 1. the gear select arm is different in the b14 tranny. if i use the b14 cable will it work? 2. the p10 drivers side axle isnt long enough where it mates with the tranny. can i use b14 axle on p10? or do i have to make some sort of frankenaxle with the b14 inner and p10 outer after the cv joint? has anyone done this
NismoB14 is offline   Reply With Quote
