Performance dwindles the closer it gets to check engine light popping up? - SR20 Forum
Old 08-19-2010, 12:14 AM   #1 (permalink)
Hi there. Have a strange problem...my stock 93 G20 is giving me a CODE 32, before and after bypassing my EGR system. If I reset my ecu (turning the screw twice), it runs like a scalded dog (fast with good throttle response) BUT the longer its driven (over a period of a few days) the slower and more laggy it gets till it finally throws the CODE 32 again and stays at that level of performance until I reset the ecu again. Anyone have any ideas? I'm thinking since it runs rich when its first learning, its for some reason running with a better curve, then maybe leaning out? Or getting more rich as its learning? I don't know what to do, but I'd love to hear some ideas!
stateofstatic is offline   Reply With Quote
Old 08-22-2010, 08:37 PM   #2 (permalink)
also thinking maybe knock sensor, but I'm not getting any code for that, just code 32...REALLLY getting on my nerves. Still no one has any ideas?
Old 08-22-2010, 10:38 PM   #3 (permalink)
TunerCode
Code 32 is caused by a problem with the ERG temperature sensor. You might try a resistor, maybe 2k ohm, between ECU pins 8 and 29.
Dave
dfddfd2 is offline   Reply With Quote
Old 08-23-2010, 10:56 AM   #4 (permalink)
Thanks Dave, I'll give that a shot...I assume I have to remove the ecu casing to get at it?
Old 08-23-2010, 11:32 AM   #5 (permalink)
TunerCode
No, I would locate the EGR temp. sensor connector in the engine compartment and connect a resistor there.
Dave
