fuel pressure is over 100psi, help!!!
Ok guys i've searched here and on google to find the same issue but no response on the fix. I have a 240z with the sr20det blacktop, the car sat for over 4 years and I just got it running a couple weeks ago. I installed a wideband o2 to keep tabs on my AFr's and yea run way too rich, idle is not too bad at about 13.5 but once I give it a slight raise in rpm i'm looking at 12.1 to about 11ish. I cleaned my MAF sensor, cleaned the AICV, swapped my FPR for the NISMO and i'm still getting 100 psi, my gauge pegs out at max. I checked to see if my return line was clogged and its free. My last resort was to check my pump (walbro GSL392 255lph) and its pushing 100+psi right from the outlet. Funny cause on the pump housing it says 60 psi max. Is my fuel pump the culprit here? The engine is stock with the 370cc injectors the only upgrade is the walbro pump and Nismo fpr, I even ran the engine with no fuel regulator just a hose and still 100psi+. Was even thinking my return line was too small, seriously it's like an 1/8" stock 240z crap. I bypassed it to rule it out with a hose straight from the FPR to a gallon. I'm stumped guys, yes the pump as for the rest of the car sat for over 4 years. This is my first post on here and yes I searched with no luck.
