so a few weeks ago i traded my car for a 90 240 hatch in beautiful condition. the car had a built sr with it and a bunch of mods done. i knew it was a a hack job but i didnt think it would be as bad as it has been. i replaced the entire harness from the smj out along with all the relays and fuse block as he had all of thease hacked to crap and deloomed under the dash inside the car. also the sr harness that came with it was trashed so i replaced that as well. i have everything finished (i think) less one plug under the hood. the sr harness is an s13 but the jun surgtank has a zenki s14 iacv with the purple and brick red plugs not the single 4 wire plug. now the iacv that is on it has no pigtails so i snached some off an 01 sentra that are the same plug but not the same color. so my question is with the 4 wires comeing out of the harness starting at the top of the plug left to right b/g , b/r, blk/y, light b im pretty sure the b/g and the b/r are for a/c wich i dont have so they dont need to be used and the light blue is the aac/isc and the blk/y is the hot to the iacv. i need to know how to wire the 2 /2wire plugs in to the 4wire plug. and please be nice ive searched my a$$ off trying to make sure its right with no luck.
thanks
steve
