leaking/hissing battery - SR20 Forum
Old 09-05-2010, 05:14 PM   #1 (permalink)
i just moved my battery to the trunk. i dont have any frayed wires, all my connections are good, and the battery has a good (and short) ground in the trunk. after the car runs for about 3-4 min the battery starts hissing, then leaking. same thing occured with both old (couldnt findthe name) and new (optima red top) battery. anyone have any ideas? thanks
se-rDriven is offline   Reply With Quote
Old 09-05-2010, 06:34 PM   #2 (permalink)
The voltage regulation portion of your Alternator is probably messed up. You can check the voltage output of the Alternator with a Voltmeter across the battery terminals. In your case, as the battery is "Hissing / Venting", I'd place the Positive lead of the voltmeter on the battery, and find a point to Ground the Negative lead AWAY from the battery. With the car running, the Alternator is supposed to be regulated to a Maximum output of 14.7 VDC. Good Luck, Be Careful.
Willbob is offline   Reply With Quote
Old 09-05-2010, 07:22 PM   #3 (permalink)
going thru life @ 1 bar
Feedback Score: 21 reviews
sounds like overcharging ^
get it checked before your battery "melts down"
...Currently down due to a clutch disc spring failure....
Old 09-06-2010, 02:16 PM   #4 (permalink)
aight
thanks for the info guys.
Old 09-06-2010, 05:10 PM   #5 (permalink)
Wouldn't the hissing be hydrogen gas escaping into the atmosphere. Prob don't want that building up in the trunk. Kapow!
zerosin is offline   Reply With Quote
Old 09-06-2010, 05:18 PM   #6 (permalink)
and/or sulphuric acid vapor
Old 09-07-2010, 10:55 PM   #7 (permalink)
its in an aluminum box with a vent tube through o hole in the trunk floorboard. but im off tmrw, so ill get a volmeter and test it, then go from there
Old 09-08-2010, 01:18 PM   #8 (permalink)
Bitter Old Man
2(Al) + H2SO4 -> Al2SO4 + H2
Al2SO4 = mud.
Bruce in Houston
1996 Dodge Viper RT/10 (RIP, Dad)
1998 Suzuki Bandit 1200S w/ $tuff, W.W.B.O.C. #101 (wanna buy?)
2007 Mazda MX-5 Touring w/ $tuff
2011 Infiniti G37S
RIP swwwinger
Old 09-11-2010, 05:49 PM   #9 (permalink)
thanks
for the info. problem solved
Old 09-11-2010, 07:20 PM   #10 (permalink)
what was it?
