A wise man once told me that the CTS must match the ECU and the dash temp sender (the small one wire sensor next to the CTS) must match the car/dash. Do your radiator fans stay on full time when the CEL is showing the CTS problem? When I had a faulty sensor it would put it into safe mode so the fans would always run just incase the car is actually hot but the ECU isn't getting a signal. But other than that my car would drive normally. Someone correct me if I'm wrong but I'm sure the cold fuel map the the car runs when started cold wouldn't dump a hell of a lot of fuel to flood it. Because that is the map it runs when you would normally start it up cold. One more thing, is the vacuum hose still plugged into your fuel pressure regulator?
N14 chassis + N15 Autech sr20de = Hybrid
