steering knuckle noise? - SR20 Forum
Old 09-25-2010, 07:18 PM   #1 (permalink)
DBA/IT
Feedback Score: 22 reviews
i have a vibrating noise coming from the front of my car. the sound speeds up or slows down depending how fast i'm going. thought it was my tires, but i put a different set on up front and the same noise is still there.
i looked under the car, and the right steering knuckle has globs of grease around the balljoint.
the noise becomes worse when i am steering left and weight transfers onto the right side of the car.
you guys think it's the steering knuckle that could be causing this noise? the whirring/vibrating noise gets pretty loud. dunno if it's the wheel bearing, because when my left front wheel bearing went out, it had a pretty distinct sound, unlike the vibrating/whirring noise i'm hearing now.
http://www.rollyourcar.com
Old 09-25-2010, 07:46 PM   #2 (permalink)
Ride or Die
i have the same whirring noise now and i know my wheel bearings are ok. im thinking might be warped rotors?
'91 NX2000
patinthehat is offline   Reply With Quote
Old 09-27-2010, 01:36 AM   #3 (permalink)
DBA/IT
umm whoops i put the wrong term in there. the tierod end's balljoint is the thing that is wasted. it is the part in question that i think may be causing the vibration/whirring noise... though i'm also kind of thinking that it's the right side wheel bearing as well now.
