Top Hat nut loose, how to tighten? - SR20 Forum
Old 10-11-2010, 07:25 PM   #1 (permalink)
n00b :)
My U12 developed a clunking sound at the front right which turned out to be the top hat nut was loose. They're standard shocks with cobra super low springs, how do I stop the inside of the shock turning so that I can tighten the top hat nut?
MOOSEcannoN is offline   Reply With Quote
Old 10-11-2010, 08:18 PM   #2 (permalink)
Don't stage if ya scurred
Interesting question.I just wrapped a rag around it and used a pair of vise grips.It works if you have a good pair of vise grips,old ones suck.Post up if there is a better way guys.
Forget graceland,i wanna go to Sugarland.Jennifer Nettles can stay with me ANYTIME.
nissannut is offline   Reply With Quote
Old 10-11-2010, 08:47 PM   #3 (permalink)
n00b :)
my springs are that compressed that nothing will be able to grab the middle of the shock lol, looks like I'll probably have to take it out. One guy said that I should just use a rattle gun on the top of it, could work?
Old 10-11-2010, 08:56 PM   #4 (permalink)
B13 Fan
Feedback Score: 12 reviews
you could hit it with an impact gun if available. if not then no need to take it out to tighten the top nut. I'm not familiar with the U12 but it should either have a place for an allen wrench on top or a flat spot where there aren't threads to ruin. If its an allen key put the right size in and hold that still while you tighten the nut with the appropriate wrench. If its a flat spot use vice grips to hold it still and then wrench it.
94sentraxe is offline   Reply With Quote
Old 10-11-2010, 09:22 PM   #5 (permalink)
n00b :)
wont attempting to tighten it with an impact gun just spin the shock as well? or ?
there's not a lot of room to get tools in the top to hold the thread and tighten at the same time, here's a pic
Old 10-11-2010, 09:27 PM   #6 (permalink)
B13 Fan
If you have one available I'd try it couldn't hurt. Looks like it does have flat spots so you could squeeze a vice grip on there, just a tight fit but looks like one would work. At least to get it down to get a better grip on it.
Old 10-11-2010, 09:31 PM   #7 (permalink)
n00b :)
I'll have to find some tools that will fit in there while I've got my vice grips on, at the moment, its too much of a tight space to be able to get any tools I have in there to turn the nut
Old 10-11-2010, 09:43 PM   #8 (permalink)
B13 Fan
You can use one of these offset wrenches
Or go at it with the open end just angled downward.
Old 10-11-2010, 09:47 PM   #9 (permalink)
n00b :)
awesome, will have to get me some of those
