Which RWD engine to start with If you want to put a VVL head on later? - SR20 Forum
Old 10-15-2010, 01:10 PM   #1 (permalink)
Ok Guys, Help me out here.
I found two different engines on eBay
First one is a S13
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Second one is a S14
What is the major difference between a S13 and a S14 ?
Thanks Tom
PROSTOCKTOM is offline   Reply With Quote
Old 10-16-2010, 05:24 AM   #2 (permalink)
the head is a lil differnt dealing with blow by and reserc also 14 trannys are stronger and geared a slight bit better and also the wireing harness conversion is a pain in the ass from 14 to 13 also gotta change the little wired thing on the back tranny that the drive shaft inserts into
oh 14 has a bit more power
sicksrs13 is offline   Reply With Quote
Old 10-17-2010, 07:39 PM   #3 (permalink)
Well If the transmission is stronger and geared better then a S14 it is.
Tom
Old 10-18-2010, 03:26 PM   #4 (permalink)
SR powered S13 coupe
McCoy's Avatar
Feedback Score: 78 reviews
Are you wanting a Turbo VE setup or an NA VE setup?
Consider the S13 or S14 SR20DE also. The cost is typically 750-1000 for a motor/tranny set. I don't see the S14 being an advantage as you are just going to pull the head anyways and your probably not going to stick with the S14 T28.
Also, the only real difference between the S13/S14 tranny is 5th gear, so nothing major to worry about there.
Old 10-19-2010, 04:12 AM   #5 (permalink)
Hybrid Power...
Yea aren't the s13 and s14 similar blocks, just the s13 head is highport and the s14 head is lowport? Either way it shouldn't matter if you're pulling the head off anyway.
N14 chassis + N15 Autech sr20de = Hybrid
UI8281 is offline   Reply With Quote
Old 10-19-2010, 08:10 PM   #6 (permalink)
S12 NUT
S14 block has an extra oil feed for the VVT valve and sprocket, which might be a good thing for the VVL head, as you could tap that for the VVL oil feed.
1987 Nissan 200SX/Silvia (S12) Specs:
  • SR20DE+T (94 S14, VCT)
  • 9.5:1 Compression (Sentra pistons)
  • T25 @ 11PSI
  • 450CC DeatschWerks Injectors @ 60PSI (528CC/min)
  • Bosch 023 Fuel Pump
  • MegaSquirt Extra 029y4
  • Custom FMIC
  • Currently maxing out injectors!
seishuku is offline   Reply With Quote
Old 10-22-2010, 12:16 PM   #7 (permalink)
I'm going to run it NA
Tom
Old 10-02-2011, 11:42 PM   #8 (permalink)
Engine and Transmission
Hey guys any thoughts on this motor set?
http://cgi.ebay.com/ebaymotors/?cmd=...K%3AMEWAX%3AIT
Thanks Tom
