weird acceleration problem - SR20 Forum
Old 11-15-2010, 05:45 AM   #1 (permalink)
hey guys i have an auto sr18de bluebird (stock). Having a problem where i have my foot planted on the gas, car gets stuck at 4000rpm for about 5 secs, then suddenly gives me a surge of acceleration and continues normally... It would happen more in 1st and 2nd gear and the surge feels more powerful than boost.. in the higher gears car just stuggles and won't go past 4000rpm.. Its an obd1..used a scan tool hooked up to my pc and didnt find any codes.. TPS and MAF are fine, only noticeable electrical issue is fluctuating voltage from the 02 sensor but i dont *** whats the normal range of voltage for this car.. Anybody with any clue what could be the problem?
girish.rambaran is offline   Reply With Quote
Old 11-15-2010, 05:46 PM   #2 (permalink)
man i get something like what you are getting my car dies down the rpm guage starts to act weird and its like my car doest want to go i give it gas and it doest rev or anything if i put it in nuetral it will die and cut of if i lave it in a gear it will surge forward in a jerking motion but i noticed this started after i threw a full bottle of redline syntectec injector cleaner im stumped if u figure it out plz post
realtime is offline   Reply With Quote
Old 11-15-2010, 07:59 PM   #3 (permalink)
tht sounds more like a fuel pump problem...mine drives fine at part throttle like nothings wrong...only under WOT the rpm literally sticks at 4k rpm, then flies up the rpm and continues as normal. no missing sputtering or jerking for me really..
Old 11-16-2010, 06:21 AM   #4 (permalink)
ok well i changed my fuel pump and it has the same problem lol did you try changing o2 sensors? another thing this only happened after using a bottle of redline fuel injector cleaner is that know to distroy o2 sensors
Old 11-20-2010, 12:46 PM   #5 (permalink)
sounds like a bad MAF to me, try giving it a clean or swapping it out for another one
TheSam101 is offline   Reply With Quote
