HElp NX2k no start - SR20 Forum
Old 11-28-2010, 04:52 PM   #1 (permalink)
HElp NX2k no start
i need help maybe **** has had this problem ...
i have a 93 nx car cranks but doesnt start no fuel no spark i checked dizzy no spark from ign. to dizzy but ign gets hot so its getting some sort of power under the dash i cant find the smaller connector to plug up i did find 3 wires of the same color that i plugged into connector still nothing some plz help thanks
srb13 is offline   Reply With Quote
Old 11-28-2010, 05:13 PM   #2 (permalink)
ahm... alway chek in this order battery, fuses, relay sensors
for an engine to start there must be 3 thing more than 650rpm if I dont remeber bad, Tº sensors and position sensor (optical distributor in this case, sorry if I dont write very well)
I hope U can fix it fast
_M7_ is offline   Reply With Quote
Old 11-28-2010, 09:53 PM   #3 (permalink)
checkd fuses switchd relay by ecu .....i jumped the car *** another car still nothing idk **** keep running down till i find it
Old 11-29-2010, 12:27 AM   #4 (permalink)
Don't stage if ya scurred
You said no fuel.Can you hear the fuel pump when you turn the key to the acc position?If you do hear it you need to turn the screw on your ecu and see how many times your check engine light flashes.It flashes fast and slow.If it flashes 5 times fast and 5 times slow you may have a big problem,that means the ecu is showing no fault code and your timing may have jumped.If it flashes something else post it and we will tell you what code it is.If you don't have a haynes manual buy one.It tells you this and a lot more.
Forget graceland,i wanna go to Sugarland.Jennifer Nettles can stay with me ANYTIME.
nissannut is offline   Reply With Quote
Old 11-29-2010, 07:45 PM   #5 (permalink)
thanks got the spark and fuel fixd now a bigger problem has come up it wont start i evn sprayd starter fuel in the intake could this mean the motor is blown
