Code 21, no spark..Help! - SR20 Forum
Old 11-29-2010, 08:05 PM   #1 (permalink)
Hey I've got an s13 sr20de that currently will not start. I had it running before I took out the wiring harness to clean it up. Now that its back in it there is no spark at the coil. I have checked everything according to the FSM and everything checks out.
I have a feeling it could be the ecu (i know it usually isn't the problem). When reinstalling the harness I accidentally switched the 02 sensor and power transistor connectors. Is it possible that the power from the 02 sensor heater wire fried my ecu??
Thanks in advance for the help!
bbalance18@mac. is offline   Reply With Quote
Old 12-01-2010, 11:51 PM   #2 (permalink)
Any help/input would be greatly appreciated!
